new shock noise
cdt785
PostPosted: Fri Mar 09, 2007 1:51 pm    Post subject: new shock noise Reply with quote
Hi.I have a 2003 Grand Cherokee that has 43000 miles on it.The rear shocks were leaking oil,so I put 2 new ones on.Now it seams to be making a noise in the rear end everytime I hit a bump.I checked them both and they are tight.Any Ideals? thanks
PostPosted: Fri Mar 09, 2007 5:39 pm    Post subject: Reply with quote
Could they be the wrong length? Are you sure they're tight? Did you check if they were tight by wiggling the shock or by checking the nuts?
cooperZJ
PostPosted: Sat Mar 10, 2007 7:12 pm    Post subject: check your Reply with quote
Check your track bar. If that comes loose it can make weird sounds too.
