Suddenly running rough, need help quick
avengerXJ
PostPosted: Sat Mar 10, 2007 8:48 pm    Post subject: Suddenly running rough, need help quick Reply with quote
Two days ago it was running perfect.
I need to drive it 700 miles to TN on Friday, and my temp gauge didn't work so I needed to fix that first. So after testing the sensor, the wires, voltage, grounds, blah blah... I figured out it was the gauge itself. Replaced the gauge and all is well... until I turn it on for the first time since two days ago.
Well, WTF... It starts normally, and it runs, and moves and all that good stuff, but the whole friggin engine is vibrating. It vibrates a little at idle (stopped, neutral, clutch in or out), vibrates heavily while accelerating, but smooth as heck when coasting in-gear (well, technically engine braking). But the second I step on the gas, or clutch, the vibrations come back.
The only two things that I have changed since two days ago was the temp gauge (not the whole cluster, just the one gauge), and I installed a new rubber boot around my shifter.
I need help finding the problem quickly, as I only have 6 days. I need to leave for my trip on friday.
I'm seriously going to cry if I can't get this running good in time for friday. I've been working on this Jeep since October and everything was good and now this is going to ruin my whole trip. PLEASE help.
Tardis
PostPosted: Sat Mar 10, 2007 10:04 pm    Post subject: Reply with quote
It would help if you indicated the year and engine size. Granted most XJ's are all the same, it's nice to know if it's OBDI(81'-95'), or OBDII(96'-present)
avengerXJ
PostPosted: Sun Mar 11, 2007 8:14 am    Post subject: Reply with quote
Sorry, I though it was in my cig, I must be seeing things.
Its a 1987 XJ 2dr, 4.0L, 5spd, 4x4
PostPosted: Sun Mar 11, 2007 10:26 am    Post subject: Reply with quote
sounds like a bad IAC or a dirty throttle body .
avengerXJ
PostPosted: Sun Mar 11, 2007 11:16 am    Post subject: Reply with quote
Just replaced new plugs, wires, cap, and rotor.
No difference.
Honestly, I'm confused as to why it would just happen so suddenly.
Tardis
PostPosted: Sun Mar 11, 2007 6:37 pm    Post subject: Reply with quote
I think you're on to something Brad. My S-10 hesitated exactly like that a few months ago. The IAC pintle and port was packed with carbon. I cleaned the pintle and port with brakekleen and it runs like a champ. Check your IAC avenger. Also check the breather tubes on the engine.
PostPosted: Sun Mar 11, 2007 7:25 pm    Post subject: Reply with quote
listen for vacuum leaks , and like Tardis said clean the IAC , i personally use mercury power tune its works a lot better then brake clean but you can use what you like . brake clean is definitely a lot cheaper.
tag
PostPosted: Mon Mar 12, 2007 8:45 am    Post subject: Reply with quote
Hi,
check the harmonic balancer, it maybe breaking down. (crank pulley) just a thought!......... Rolling Eyes
TheBrat97
PostPosted: Mon Mar 12, 2007 9:26 am    Post subject: Reply with quote
tag wrote:
Hi,
Not a bad idea but I think it would probably still vibrate while coasting.
tag
PostPosted: Mon Mar 12, 2007 9:46 am    Post subject: Reply with quote
yeah, your right , but a unbalanced wheel runs smooth at the right speed.
TheBrat97
PostPosted: Mon Mar 12, 2007 2:44 pm    Post subject: Reply with quote
true true
avengerXJ
PostPosted: Wed Mar 14, 2007 1:11 pm    Post subject: Reply with quote
Alas, the problem located... @#$% clogged fuel injectors. I guess it wouldn't hurt to replace them after 315k miles.
