abs light on
rix
PostPosted: Tue Apr 10, 2007 5:20 pm    Post subject: abs light on Reply with quote
My abs light came on recently. I have checked all the connection at each wheel and under the rear seat, all appear to be fine. The fluid level is good. Anybody have any suggestions?
Also how bad would it be to do nothing about? The brakes work fine,maybe the fron left brake pulls a little but the stopping power is still there
PostPosted: Tue Apr 10, 2007 5:34 pm    Post subject: Reply with quote
Check the front pads and rotors, they might need a changing.
PostPosted: Tue Apr 10, 2007 5:41 pm    Post subject: Reply with quote
If that's the same wheel that the wobble is occuring, then get that tire off and make sure it's all good. The abs gear might be damaged from the excess tire movement. You don't want that tire coming off while driving.
PostPosted: Tue Apr 10, 2007 9:24 pm    Post subject: Reply with quote
to do nothing about it would just leave you using normal non-abs brakes i would check out your pads ,rotors and tone ring for irregularities.
rix
PostPosted: Wed Apr 11, 2007 1:47 am    Post subject: Reply with quote
what are tone rings? if that is the spline looking wheel then they are pretty gummed up.
PostPosted: Wed Apr 11, 2007 6:28 am    Post subject: Reply with quote
Just clean it up. That's probably the reason for the abs light.
