What is spring wrap, and how to fix it?
emr454
PostPosted: Wed Apr 11, 2007 7:08 am    Post subject: What is spring wrap, and how to fix it? Reply with quote
Hi all, just wondering what exactly is spring wrap and how it is fixed. I ask because I have clunking noise coming from the back end of my jeep. It happens when:
I'm going down the road and I let off the gas, I hear a clunk and there is some noticeable movement in the rear end.
If I take off fast I hear a clunk, but I'm not sure where it comes from(I try not to do this too often!)
It only happens in 2WD, havent heard it yet when its in 4WD.
Is this spring wrap? If so, can I just replace the springs and get rid of the problem? Thanks in advance for your help.
Eric
PostPosted: Wed Apr 11, 2007 7:39 am    Post subject: Reply with quote
Spring wrap can be caused by weakened leaf springs usually with lift blocks under them. The rear end begins to twist under the spring. Basically the rear end moves front to back or back to front instead of just up or down with the springs. Are you lifted or stock? If you do have spring wrap, new springs will fix it. I lifted mine with s10 leafs, got rid of the spring wrap and achieved 4.5" of added height.
emr454
PostPosted: Wed Apr 11, 2007 10:40 am    Post subject: Reply with quote
Its all stock right now. It might not be spring wrap then if its not lifted? I think I have to replace the yoke in the rear differential, so that might be the cause of the noise. I'm about to pick up 2 cherokee's this weekend for parts, ans if the springs are in better shape I might replace them anyway. The back end isnt sagging too bad now, but you can notice a slight difference between the front and the back.
One more question, if I do the S10 spring swap, do I HAVE to get new shocks for the rear, or is that just an option? Thanks!
Eric
PostPosted: Wed Apr 11, 2007 11:02 am    Post subject: Reply with quote
its also called axle wrap. It sounds like you have the rear end clunk if your sure its in the rear it could be the pinion bearings or the crush sleeve
if you think its closer to the front it could also be a trans mount at the crossmember
does the jeep upshift when you let off the gas and then it does it?
PostPosted: Wed Apr 11, 2007 12:49 pm    Post subject: Reply with quote
Yes, you would need new shocks with s10 springs.
emr454
PostPosted: Wed Apr 11, 2007 4:00 pm    Post subject: Reply with quote
It sounds like its towards the rear end, but I'll check the tranny mount first since that seems to be an easier fix.
It doesnt upshift when I let off, it just makes a clunk noise when I'm driving and let off the gas. I'll be geting a few parts off of 2 XJ's this weekend and I'm going to go through and check the whole rear suspension and fix what I can.
As far as the S10 springs go, I might pass on that idea for now and see if the springs on the 2 donor vehivles are in better shape and swap them. I dont want to lift the rear end too high, just get it back to where it should normally be.
Eric
JeepinNH
PostPosted: Wed Apr 11, 2007 7:04 pm    Post subject: Reply with quote
The stock springs are really soft and easily do the spring/axle wrap annoyance. I added Hellwig helper springs to the front of my springs for a temporary fix and it stopped the wrap completely. I replaced the springs once already, next time will be the towing package ones. The tell tale sign is braking relatively hard to a stop and when letting off the brakes the rear end will feel like it drops and you get a clunk sound.
Mike
Present: 99 Cherokee
PostPosted: Wed Apr 11, 2007 8:28 pm    Post subject: Reply with quote
if you really have a problem with it and you make your leaf packs then cutyour leaf packs off-set with more leaf material on the front then the back , just like on a mopar from the late 60's -70's Smile
