headlights, fule pump don't always shut off ?
carpetrugger
PostPosted: Fri Apr 20, 2007 10:19 am    Post subject: headlights, fule pump don't always shut off ? Reply with quote
Iam working on my 87. I know the batt. has a shorted cell but it holds a charge for a few days and don't want to replace untill I get this problem fixed so I don't damange the new one. As long as the battrey has a good charge the fule pump will come on when the key is turned on and run for a few seconds and stop when the pressure builds up. It holds the pressure without leaking. When I turn the key to the start run possition it starts after about three seconds, this is normal I think. But when the battrey is low, where it turns over to slow to start it the fule pump will start again and continue to run even with the ingnition off and the key out. I have to pull the ground cable off the batt. to get it to stop running. When the pump runs like this I here air pressure escaping from under the hood and and fule pump area. This onley happens when the batt. is low. Also a few times I have turned the headlights off and they stay on for a couple of minits but not all the time. I already changed the ingnition switch and this changed nothing. Any idea's? Iam out of them thanks
carpetrugger
PostPosted: Sun Apr 22, 2007 10:33 am    Post subject: Reply with quote
Hi and thanks to everone who looked at my post. I called a freind of mine in Calif. who is a elctronics enginer, he also likes to tinker with cars anyways he found a found a wiring diagram on line somepalce for my 87 and told me theres a fule pump relay that is activated by the PCM when the ingnition switch is in the run position. This is working when I first try to start it with the batt. in a low state but after cranking it till the batt. wont turn it over anymore theres not enough charge left in the batt. to operate the PCM (computer) to shut down the fule pump relay but enough to run the pump for awhile longer. He also told me to replace the battery right away because all the elctrical systems can be affected by a low shorted out battery. So I installed a new battery and headlight switch. With the new battery I don't hear the hissing from the fule sytem anymore but I am going to buy a fule pump pressure tester and run a complet check on the system. I will drive it for a few days and let you know if this takes care of the problem in case any of you ever have the same problem. Thanks to all
Glowyrm
PostPosted: Sun Apr 22, 2007 12:33 pm    Post subject: Reply with quote
Your headlights also have a "follow me home" feature. When you turn off your engines then the lights, the headlamps(nothing else) will stay on for 60 sec.
PostPosted: Sun Apr 22, 2007 8:58 pm    Post subject: Reply with quote
fuel . sorry had to , i meant no offense
carpetrugger
PostPosted: Wed Apr 25, 2007 7:30 am    Post subject: Reply with quote
None taken. However embarrassed a little but smiling, had to laugh at self. I have put about a hundred miles on the Cherokee so far without any problems. Running on a new battery, maybe to soon to tell if problems are fixed. Sorry about spelling, I have problems with it
carpetrugger
PostPosted: Wed May 09, 2007 10:21 am    Post subject: Reply with quote
The new batt. did the trick, no problems with anything. I did replace the headlight switch witch I didn't need to do as Glowyrm said it was working as it was supposed to. I just got the information a day late. Thanks
Glowyrm
PostPosted: Thu May 10, 2007 6:59 am    Post subject: Reply with quote
save the old one. Somebody will need it.
'87 XJ Chief w/tow pack. Dana 30/44 f/r
3.5" lift 4.88 gears NP242 t-case
Numerous junkyrd doodads
31x10.5's
cksport
PostPosted: Sun May 20, 2007 12:28 am    Post subject: Reply with quote
my old Camaro did the same thing dead battery
