RE 4" Lift
dougfunny2020
PostPosted: Wed May 02, 2007 11:48 am    Post subject: RE 4" Lift Reply with quote
What, if any, acessories should you purchase with this kit for optimal flex? I've read that if not setup with certain shackles it will nto flex very well, is this true?
5.9 andy
PostPosted: Sat May 05, 2007 8:13 pm    Post subject: Reply with quote
i dont now about a preticular set that is required to make it work best, but if u got the $$$ get some tera-flex shackles, they are soposta increase your down travel by about 6" if i am correct, i know at least 4".
go check out the tera-flex website.
teague yj
PostPosted: Tue Sep 18, 2007 7:19 am    Post subject: Reply with quote
you might want to take your sway bars off or buy swaybar disconnects http://www.quadratec.com/products/16060_02.htm disconnect will allow good on road ride when connected and wicked flex when disconnected
