switching drivetrains
Leejr57
PostPosted: Sat Jun 02, 2007 4:19 pm    Post subject: switching drivetrains Reply with quote
I have the '96 as mentioned in an earlier post, I also have a '95. the '96 is a 5.2, the '95 is a 4.0. I would like to change the drivetrain from the '96 into the '95. The rear end ratios are different , so I'll have to change both ends. My Question is, the '95 has 3.55 gears, the '96 has 3.73 gears. Does anyone think I'll have any performance problems with the swap?
PostPosted: Sat Jun 02, 2007 5:51 pm    Post subject: Reply with quote
What part of the drivetrain are you swapping?
Leejr57
PostPosted: Sun Jun 03, 2007 4:04 pm    Post subject: Reply with quote
I'm swapping the front and rear axles from the '96 to the '95
PostPosted: Sun Jun 03, 2007 5:42 pm    Post subject: Reply with quote
Oh ok! You'll be fine, the 3.73's are better. Why are you're swapping? Are the 95 axles toasted?
Leejr57
PostPosted: Mon Jun 04, 2007 1:48 am    Post subject: Reply with quote
Yes, the front axle seems to have stripped the splines on the axle gears inside the carrier. The '96 has a 5.2 with over 200,000 miles on it, pretty much used up!
PostPosted: Mon Jun 04, 2007 7:19 am    Post subject: Reply with quote
Only 200k that's nothing!!! rofl rofl rofl
Did you open up the diff? Are the spiders gone or the axle shafts? You could just swap the insides (shafts and spiders) from the 96 to the 95 and save some time and labor. Mr. Green
Leejr57
PostPosted: Mon Jun 04, 2007 2:59 pm    Post subject: front diff swap Reply with quote
ok just finished the swap what a pain that was-never again!!! now when i turn the wheels hard to the right it "clunks" everything is tight i checked 3 times. however the torsion bars fought a little while tightning. could they not be tight enough? i cant get them any tighter?! what am i missing?doing wrong? by the way the jeep isnt on stock wheels but that shoudnt matter rihgt?
PostPosted: Tue Jun 05, 2007 6:33 pm    Post subject: Reply with quote
u joints perhaps
5.9 andy
PostPosted: Fri Jun 08, 2007 3:25 pm    Post subject: Reply with quote
tortion bars???
jeep grand cherroke's dont have tortion bars...for that matter..no jeeps have em. they have coil springs. or leafs. two cents
