Short Arm vs. Long Arm?
DelmarvaXJ
PostPosted: Fri Jun 01, 2007 5:40 am    Post subject: Short Arm vs. Long Arm? Reply with quote
What are the differences and advantages of running a long arms vs. the standard short arms? I'm not quite understanding the advantages of the long arm kit? From reading the NAXJ website, they say that the long arms are the only way to go... They say that the ride is softer, and more responsive, and rock climbing is made easier with the long arms, but I want to know why?
PostPosted: Fri Jun 01, 2007 7:45 am    Post subject: Reply with quote
Basically long arms are the best way to keep the suspension geometry where it needs to be. The higher the Jeep is lifted, the sharper the angle gets on the stock or short arms. The long arms solve this problem. If you got the cash get the long arms, if not get some adjustable short arms, or control arm drop brackets.
5.9 andy
PostPosted: Fri Jun 01, 2007 11:24 am    Post subject: Reply with quote
stay away from drop brackets, i have heard that they are VERY prone to being smashed on rocks.
long arms basicly give you more flex and let u do FATTY lift kits.
PostPosted: Fri Jun 01, 2007 11:34 am    Post subject: Reply with quote
As orange said, it's all about geometry. Imagine a right triangle made up of the spring, frame and control arm. As the spring gets taller, the angle for the control arm to still connect to the frame and axle grows. As the angle gets steeper, it moves the axle further back, effectively shortening your wheelbase. So when you hit a bump, instead of the stock angle which causes the front control arm to move up and back, the control arm has to move forward and up which causes a harsher ride. A long(er) control arm gets the angle back closer to stock (i.e. parallel to the frame) which returns the wheelbase closer to stock and improves the ride and handling.
DelmarvaXJ
PostPosted: Fri Jun 01, 2007 12:46 pm    Post subject: Reply with quote
Nice explaination, thanks Very Happy I'm looking into either the RE 5.5" LA kit or Rusty's 6.5" LA kit, there's not much of price difference. All I want is to fit 33x12.5" wheel/tire combo which keeping it streetable, and can handle sand dunes.
berk9
PostPosted: Sun Jun 03, 2007 11:36 am    Post subject: Reply with quote
i have the drop brackets on my xj with 6 inch lift and yes they do hit rocks a lot. all the drop brackets do is correct the angle of the short arms but if you think about it the drop brackets are going to be the exact same height off the ground as the long arms unless you get high clearance arms which tend to be weaker then norm long arms. you gain and lose things from both drop brackets and long arms. my biggest problem with my drop brackets have been strength related because they arent braced. i also score over a 1000 on an rti so like i said you gain and lose
front 9" arb chromos 4.56s warn hubs; rear 8.8 detroit and 4.56s; rustys crap long arms crossmember and coils; RE leafs; rusty boomerang and 2' block; oh and trimming gotta love that sawzall
DelmarvaXJ
PostPosted: Mon Jun 04, 2007 6:47 am    Post subject: Reply with quote
This might be a stupid question, but since I'm relatively new to offroading, what exaclty is a drop bracket? Is it the same as the pitman arm or the mounting point of the front control arms? Again baer with me i'm a newbie... Very Happy
PostPosted: Mon Jun 04, 2007 7:49 am    Post subject: Reply with quote
It is the rear frame mounting point on the control arms. Like Berk said it allows you to run short arms and still have the correct geometry.
Control Arm Angles
Bracket on a TJ
Here's a write up on an XJ with photos
DelmarvaXJ
PostPosted: Mon Jun 04, 2007 2:51 pm    Post subject: Reply with quote
Control Arm Angles
Bracket on a TJ
Thanks for the explaination, any pics of the drop bracket installed on an XJ? Also why does the RE website list the drop bracket, and how much does it run?
PostPosted: Mon Jun 04, 2007 3:13 pm    Post subject: Reply with quote
DelmarvaXJ
PostPosted: Mon Jun 04, 2007 3:31 pm    Post subject: Reply with quote
Cool I noticed that the RE 5.5" short arm kit does come with the drop brackets. But good to know that they are use full and I can buy the seperately if I decide to go with a different company.
PostPosted: Tue Jun 05, 2007 6:14 pm    Post subject: Reply with quote
RE drop brackets with braces run about 325 or so on ebay
heres a couple pics
Berks
And another friend, Lil Hoss
DelmarvaXJ
PostPosted: Wed Jun 06, 2007 5:55 pm    Post subject: Reply with quote
heres a couple pics
Berks
What's the lift and tire combo on the red xj? thanks
berk9
PostPosted: Wed Jun 06, 2007 7:16 pm    Post subject: Reply with quote
look at my signature to see my set up. lots of trimming + more since that pic
PostPosted: Wed Jun 06, 2007 8:15 pm    Post subject: Reply with quote
Heres a short arm kit, flexed
and sittin level
i wish i had drop brackets, It would help my flex
