transmition problem
mark Anthony
PostPosted: Tue Jun 05, 2007 10:11 am    Post subject: transmition problem Reply with quote
Hi, can any one help, i have a 2000 model grand Cherokee 4.0L, for the last week when i do around 55 to 60 it seems to drop down a gear & back up again, now i have lost overdrive no o/d light on dash , i have also noticed a clonk when it goes into 3rd gear, have checked the transmission fluid & that is OK, looked underneath & can see oil has been coming out the rear shaft on the transfer box, this may or may not have anything to do with it but i thought i would mention it, pleas help anyone Crying or Very sad
wan2live
PostPosted: Tue Jun 05, 2007 4:55 pm    Post subject: Reply with quote
No codes?
mark Anthony
PostPosted: Tue Jun 05, 2007 11:59 pm    Post subject: Reply with quote
No, i don't have a code reader, the engine check light is on
PostPosted: Wed Jun 06, 2007 11:04 am    Post subject: Reply with quote
if its leaking fluid be sure to check the level in the transfer case, there should be two big bolts, and its possible they could be allen head. The upper bolt is for filling the lower is to drain the case. Take the upper bolt out, while on level ground, if fluid comes out your in the green, if no fluid comes out, add some auto trans fluid until it starts to run out.
as for the trans, mopar has been known to have crappy torque converters. I lost O/d in my grand and it was because of the torque converter.
unfortunately the only way to check is to remove the trans, go through it, and then have the converter checked.
But you do have a check engine light so I would first take it to a dealer to see if they can pull any thing up on it
cajzmere
PostPosted: Wed Jun 06, 2007 7:28 pm    Post subject: Reply with quote
Damn those computers!! pissed
mark Anthony
PostPosted: Fri Jun 08, 2007 4:53 am    Post subject: Reply with quote
Hi, i just got a code reader & have 9 codes come up, 0181, 0600,0089,2300,0123,3100,8106,0031,310a, some are in the code book but 310a,8106,0600 are not included, i think they are all linked to the pcm as i think all the censors would not fail at once ? also its some times runs erratically when started, when i turn it of then back on again it runs ok
mark Anthony
PostPosted: Sun Jun 10, 2007 6:28 am    Post subject: Grand Cherokee has built in fault code reader Reply with quote
DOH!, just found out i don't need a OBD 2 code reader, my Cherokee has one built in, just had to turn the ignition on & off 3 times without starting the motor, then the fault code is displayed on the mileometer, LOL, the only code that came up was P0123, ( throttle position sensor ) sensor was OK but the wires has rubbed on the manifold & earthed out rofl
