new to off roading needing some advice
gcm215
PostPosted: Wed Jun 13, 2007 1:03 pm    Post subject: new to off roading needing some advice Reply with quote
yeh i just got a 1996 jeep grand cherokee laredo and i was wondering if u guys could help me get started with some purchases for it
oh yeh my budget for the moment is 3 grand and the jeep has the 4.0 ltr
PostPosted: Wed Jun 13, 2007 7:27 pm    Post subject: Reply with quote
tires , tru tracks or lockers , lift
what kind of offroading do you want to mostly do ? mudding ? rocks? trails ?
PostPosted: Wed Jun 13, 2007 8:58 pm    Post subject: Reply with quote
yup lift and tires.. Personally I would hold off on lockers till you can afford axle work.
But what do I know I'm just a web wheeler. Razz
monkeyman3875
PostPosted: Thu Jun 14, 2007 3:50 am    Post subject: Reply with quote
Make sure to save about $100 for a CB just in case you get stuck without a phone. Maybe you'll get lucky on the CB.
-1997 Stock XJ
-4.0 L
-4-speed automatic
cajzmere
PostPosted: Thu Jun 14, 2007 6:57 pm    Post subject: Reply with quote
HI-lift jack, like this http://www2.northerntool.com/product/200310544_200310544.htm
Works not only for jacking up, but also for winching out.(slowly) Shocked
gcm215
PostPosted: Sat Jun 16, 2007 4:44 am    Post subject: Reply with quote
trails
jppilot61
PostPosted: Sat Jun 16, 2007 9:03 am    Post subject: Reply with quote
Get with locals who wheel off-road (join a club?)
For milder trails, you may be AMAZED what a stock JEEP will do. More experienced drivers will help spotting appropriate lines and advice as to how to negotiate obstacles but I find myself still shocked how capable these vehicles are (even in stock form they are quite trail capable!)
Disconnecting front Sway Bar (Anti-Sway Bar if you prefer), airing down tires are two inexpensive/free mods further increasing even stock capabilites.
Get some trail experience and then proceed with the modification process. But be warned: It is addictive (not to mention expensive!)
1992 XJ Laredo
RE6130 4.5" XJ Super-Flex Kit
DankNesS
PostPosted: Sat Jun 16, 2007 3:14 pm    Post subject: Reply with quote
yeah what he said very very much so- addicting and $$$$$$$$$
PostPosted: Tue Jun 19, 2007 7:41 pm    Post subject: Reply with quote
ugh , my radiator exploded the other day there goes a few 100 $ . except i torch soldered it back together , i wonder how long it will work .
anything swampy says is probably right , like the axle work or axle swap idea he shot out of his web wheeling behind .
stock jeeps do pretty good off road you can usually get water to go into the cab and jump them a couple feet ( not saying they will last forever )
