95 ZJ 5.2 4X4 BINDING
Goto page 1, 2  Next
JOHNB279
PostPosted: Fri Jun 22, 2007 8:32 pm    Post subject: 95 ZJ 5.2 4X4 BINDING Reply with quote
i purchased a 95 5.2 zj.it binds like hell on tight manuvers.its full time 4x4.is this normal? i have an explorer full time,it doesn't do it.of course my 88 wrangler doesn't either,its not full time 4x4.Also there is a whine in the driveline,maybe rear,maybe transfer case,which is more prevalent.thanks
DankNesS
PostPosted: Fri Jun 22, 2007 10:48 pm    Post subject: Reply with quote
id say its your poopy 249! it shouldnt bind unless you blew your vc which prevents binding in the all wheel tcases. its a pile of dung tho so id say swap it out for either a 242 or 231
since you said the noise is from the rear check drive shafts and u joints
PostPosted: Sat Jun 23, 2007 6:04 am    Post subject: Reply with quote
X2
Also check the fluids in both diffs and the t-case!
PostPosted: Sat Jun 23, 2007 11:46 am    Post subject: Reply with quote
x3
PostPosted: Mon Jun 25, 2007 4:34 pm    Post subject: Reply with quote
Quatro
DankNesS
PostPosted: Mon Jun 25, 2007 7:25 pm    Post subject: Reply with quote
awww shuks yawl make me feal alle smatre' and stuf!
JOHNB279
PostPosted: Tue Jun 26, 2007 3:37 pm    Post subject: Reply with quote
Thanks,i guessed it was the transfer case,of course after reading the tech pages.I am going to remove the front driveshaft for now,untill i find the right transfer case.Thanks for all that replied.
DankNesS
PostPosted: Tue Jun 26, 2007 10:13 pm    Post subject: Reply with quote
i may be wrong but i think only 96+ 249 tcases can be run with out the front dirve shaft with out problems... i could be wrong it is definately some thing to look into i know my 93 couldnt
Brad S
PostPosted: Wed Jun 27, 2007 5:32 am    Post subject: Reply with quote
Mine is a 95 and I ran it without the front drive shaft. What kind of problems might you encounter?
Of course, my tcase had bound up so bad on the highway that it shredded my front diff. gears so that could be why I didn't have any other problems.
PostPosted: Wed Jun 27, 2007 6:12 am    Post subject: Reply with quote
If anything it will ruin the t-case, but if it's already shot I wouldn't worry. I've driven my 94 a few days without the front driveshaft with no problems, when the 249 was still in.
PostPosted: Wed Jun 27, 2007 7:56 am    Post subject: Reply with quote
maybe dankness is talking about how some of them work like a differential between the front and rear tires ? and with out the front shaft it would just spin the out put yoke and not the rear tires .
or maybe not .
im sure hes fine .
DankNesS
PostPosted: Wed Jun 27, 2007 8:17 am    Post subject: Reply with quote
i guess go for it!
monkeyman3875
PostPosted: Wed Jun 27, 2007 11:59 am    Post subject: Reply with quote
just out of curiousity....why would removing the driveshaft affect the ride and mess up the TC?
-1997 Stock XJ
-4.0 L
-4-speed automatic
monkeyman3875
nevermind....re-read posts. got my answer
-1997 Stock XJ
-4.0 L
-4-speed automatic
PostPosted: Wed Jun 27, 2007 12:03 pm    Post subject: Reply with quote
you wouldnt have 4x4 Smile economy would be up and the ride should be better .
Goto page 1, 2  Next
Page 1 of 2
