1993 gc stalling problem
Johann
PostPosted: Sat Jun 30, 2007 2:34 pm    Post subject: 1993 gc stalling problem Reply with quote
I am new here, and I have a problem.. go figure ..
Well my problem is that I start my gc and drive for a few minutes and then it stalls and dies. I try starting it but the engine turns and nothing happens. After a few minutes I can start it and it runs for a few hundred meters and dies again.
I have a 4 liter 6 cyl engine ....
I do not have a engine manual so I would need directions in locating the things that need inspecting ( sorry that my english is not good.. I am from Iceland)
PostPosted: Sat Jun 30, 2007 4:45 pm    Post subject: Reply with quote
Sounds like you IAC needs to be cleaned or replaced.
Johann
PostPosted: Sun Jul 01, 2007 3:14 am    Post subject: Were is tha IAC ? Reply with quote
Were can I find the IAC? and what is the best way of cleaning it?
PostPosted: Sun Jul 01, 2007 7:11 am    Post subject: Reply with quote
The IAC is Idle Air Control. Here's a pic. You'll need a can of carb cleaner. Spray the throttle body inside and out. Clean the port that IAC sits in really good, it's probably full of carbon. Then clean the pintle on the IAC thoroughly, it's the mushroom shaped thing, make it shine if possible. Hopefully this is it, if not post up and we'll move on to the next thing.
PostPosted: Sun Jul 01, 2007 10:49 am    Post subject: Reply with quote
could also be crank sensor or fuel pump
Johann
PostPosted: Sun Jul 01, 2007 11:39 am    Post subject: I really need a owners manual to find these things... Reply with quote
Were is the crank sensor?
PostPosted: Sun Jul 01, 2007 1:18 pm    Post subject: Reply with quote
top of the bell housing, drivers side, 10mm bolts hold it in
PostPosted: Sun Jul 01, 2007 5:02 pm    Post subject: Reply with quote
Normally when the CPS goes out you cant start at all.. So IAC or TPS are good places to start..
Johann
PostPosted: Mon Jul 02, 2007 12:35 pm    Post subject: Reply with quote
I have cleand the IAC, and yes I found carb-cleaner here in Iceland Wink but nothing changed.
Well now I am down to the fuel pump ( I think) .. after a few test and trials I found out that there is not enough fuel flow to the engine.
Is the fuel pump in the tank? Can I test the fuel pump, just find out if it is the wiring or the pump?
By the way, your answers here have been great.
cajzmere
PostPosted: Mon Jul 02, 2007 2:17 pm    Post subject: Reply with quote
Here's everything you need to know about fuel pumps and then some!!
http://jeephorizons.com/phpbb/viewtopic.php?t=62 shock
PostPosted: Tue Jul 03, 2007 2:32 am    Post subject: Reply with quote
swampy when my CPS went out it I would have to wait a few minutes to start it, as did berk9
yes pump is in the tank, if you dont mind cutting do the swampy bypass
Johann
PostPosted: Tue Jul 03, 2007 1:18 pm    Post subject: Reply with quote
I think that is a good idea. Does the same pump work for the 6 cyl engine?
PostPosted: Tue Jul 03, 2007 1:26 pm    Post subject: Reply with quote
if you mean the process then yes it is the same, as for the pump I'm not sure they could be different
PostPosted: Tue Jul 03, 2007 4:00 pm    Post subject: Reply with quote
Fuel pressures are very similar V8 and I6 so the same pump should work..
