View previous topic :: View next topic |
Author |
Message |
black97xj Member
Posted: Wed Jul 04, 2007 7:46 pm Post subject: possible to use front shocks with an eye on each end? |
i just put a 2 inch lift on my 97 xj. the kit came w/ pro comp explorer shocks. for the rears, all i had to do was press the bar pin into the upper eye to make them bolt right in. not so simple for the fronts: the shocks are identical to the rears, w/ an eye on both ends. in all my infinite wisdom, i failed to realize that the stock shocks have a threaded bolt on the upper end. is there any way to run a shock w/ an eye on each end on the front, or am i best off trying to exchange them for ones w/ a similar setup as the factory pieces? any info on this would be greatly appreciated. thanks. |
Back to top |
Teriod Member
Back to top |
quadna71 Member
Back to top |
black97xj Member
Posted: Tue Jul 10, 2007 12:16 pm Post subject: |
thanks for the info- i just ended up swapping the shocks for the correct ones, figured that would be the easiest thing to do. now i just have to get rid of the vibrations caused by the lift... |
Back to top |
