Brake lights don't work
McJeep
PostPosted: Tue Jul 10, 2007 10:39 am    Post subject: Brake lights don't work Reply with quote
I've been lurking here quite sometime.I know you guys are fortress of knomledge,so here's my prob.I have tail lights, turn signals,but no brake lights.On top of that my after market cruise control won't engage.My buddy the mechanic thinks its the relay.Fuse is good.Where is the relay,and does that sound correct.
blktrax
PostPosted: Tue Jul 10, 2007 5:39 pm    Post subject: Reply with quote
It most likely is your brake light switch located under the steering column above the pad of the brake pedal. This not functioning or not connected would cause your cruise not to work as it disengages the cruise when you depress the brakes. Remove the panel right under the steering column and the metal plate be hind that and you should be looking right at it.
fuses are located behind the glovebox and under the hood, passenger side, in front of the battery. Brake lights do not have a relay only a fuse; and im too lazy at the moment to go out in the rain to see witch one has the brakes fuse in it.
Also remember if you did blow a fuse, it did it to prevent an electrical overload and a possible fire. Thats what fuses are for. If one did blow you need to find the reason why, not just replace it.
