vibrations after lift
black97xj
PostPosted: Wed Jul 11, 2007 9:25 pm    Post subject: vibrations after lift Reply with quote
i just finished putting a 2 inch lift (AAL and front spacers) on my 97 cherokee. i've read that some cherokees can be lifted up to 4 inches without causing any vibrations, and that vibrations can occur in others with small lifts, such as mine. i'm noticing some vibrations, i'm assuming from the rear driveshaft, under acceleration and to a lesser degree under deceleration. i know i could install a 1 inch transfer case drop to try to remedy this, but i'm wondering if i should try anything else first? it has been suggested that i replace my u-joints and get my driveshaft balanced. the jeep has 130k miles on it, but was completely smooth before i installed the lift. i suppose the greater angle between the t-case and rear axle could magnify any wear in the u-joints or imbalance in the driveshaft, but i really don't know. i know this is a relatively common problem with lifted jeeps, so i was wondering if anyone had any ideas on what i should try? thanks.
rbjeepster
PostPosted: Wed Jul 11, 2007 10:53 pm    Post subject: Re: vibrations after lift Reply with quote
when i lifted my jeep the first time to three inches i considered the vibrations and from what i heard at three inches the drive line angle wouldn't be an issue. the first thing i would do if i were u is to just pop in new u joints theyre cheap and it could keep u from spending any more money on the problem. when i lifted my jeep the second time to two more inches i went ahead and bought a one inch t-case drop because at five inches i was most likely to feel some vibration, they were really cheap but i did have to sacrifice some ground clearance not much but some. so yeah ur u joints might have been aggravated due to the lift and it might only be a problem as small as that check them out first
PostPosted: Thu Jul 12, 2007 6:36 am    Post subject: Reply with quote
Sometimes shimming the rear end will solve the problem.
Teriod
PostPosted: Thu Jul 12, 2007 8:52 am    Post subject: Reply with quote
x2 they make degreed shim for between the axle and the leaf springs in 4 degrees and 6 degrees to tilt the differential up and decrease the angle between the the axle and the tc, i used both tc drop and shims to eliminate vibes on my yj
IBTJn
PostPosted: Thu Jul 12, 2007 10:33 am    Post subject: Reply with quote
I'm no XJ expert, but my first thought/question was did you use the original springs? If so, that probably merely put it back to just over stock (new)height with the normal spring sag that I've always seen on XJ's.
Just a thought, but when we did the 2" OME lift (which included complete new springs) we didn't need to shim the rear axle at all or do a TC drop (even though TC shims were included in the kit). I tend to agree that the U-joints are a likely culprit and should be addressed/looked at no matter what you find. They are relatively cheap to replace anyway to be sure.
Just a couple of things that come to my mind.
Wink
black97xj
PostPosted: Thu Jul 12, 2007 7:29 pm    Post subject: Reply with quote
thanks for all the responses, guys... looks like i know what i'm doing on saturday (u-joints) if that doesn't do the trick i'll look into shims or something.
