1995 JEEP YJ LIFT HOW TO TELL HOW MUCH LIFT YOU HAVE
EDHASCALL
PostPosted: Mon Jul 16, 2007 7:31 pm    Post subject: 1995 JEEP YJ LIFT HOW TO TELL HOW MUCH LIFT YOU HAVE Reply with quote
I JUST BOUGHT A 1995 YJ THE GUY I BOUGHT IT FROM DOESNT KNOW HOW MUCH LIFT IT HAS...BUT ITS RUNNING ON 33 12.50 15 WHEELS AND TIRES AND GETS AROUND JUST FINE THE ONLY REASON I NEED TO KNOW IS THAT I WAS GOING TO ORDER NEW SHOCKS FOR THE BACK AND NEED TO KNOW THE AMOUNT OF LIFT TO GET
PostPosted: Mon Jul 16, 2007 8:11 pm    Post subject: Reply with quote
Post a pic of your YJ and suspension. I will guess about 3-4". From the ground to the rocker measures 18" on a stock YJ. The best way to tell would be to measure from the center of a hub to the bottom of a flare, but I'm not sure of the measurment on a YJ.
Just a heads up, don't post with all caps, it's frowned upon. It means your pissed off. Cool
hcreamer
PostPosted: Wed Jul 18, 2007 7:32 pm    Post subject: Reply with quote
The way it was described to me was to drive one side of the Jeep up on a ramp so that it compresses the shock on one side and extends the shock on the other side. Then you measure the shock on each side from mounting bolt to mounting bolt and that will give you the travel distance for the shock.
You can then use those measurements to pick out your new shocks. You will need to do this both in the front and back. I know it doesn’t help find the amount of lift that you have but it tells you what size shocks to buy.
I hope this helps.
Jesse
hcreamer
PostPosted: Sat Jul 21, 2007 8:49 am    Post subject: Oh, I forgot... Reply with quote
Take the shocks off the Jeep before you do this so you get the most travel. Then measure between the mounts to get your range of motion for the shock.
EDHASCALL
PostPosted: Fri Jul 27, 2007 4:04 pm    Post subject: Reply with quote
thanks alot i pretty sure i know what to get noe thanks again
