about 2 start T-case swap
5.9 andy
PostPosted: Tue Jul 24, 2007 5:56 pm    Post subject: about 2 start T-case swap Reply with quote
im about 2 start my 231HD tcase swap, i got every thing prety well planed out, just looking for some advice as to what 2 look out 4 when doing this?
my T-case came out of a 1993 doge durango, and it has been rebuilt recently, i dont know how long ago, ill get that info later.
cajzmere
PostPosted: Tue Jul 24, 2007 7:01 pm    Post subject: Reply with quote
http://jeephorizons.com/phpbb/viewtopic.php?t=694&highlight=
Smile
5.9 andy
PostPosted: Tue Jul 24, 2007 7:22 pm    Post subject: Reply with quote
not 2 sound like a smart @$$ but i now have a new question...
i have read that thread and every other one that involves a T-swap at least 3 times, should that b enough to prepare me 4 everyting?
PostPosted: Wed Jul 25, 2007 11:22 am    Post subject: Reply with quote
When I did my tcase swap all I had to go by was a really crappy writeup that someone did on another forum..And I got thru it..
It was my primary reason to do my writeup.. You should be fine.. Its really not that hard..
Brad S
PostPosted: Wed Jul 25, 2007 11:37 am    Post subject: Reply with quote
Its pretty easy. If you get into it and run into any problems, just post them up, someone will help you out. Swampy's write up did the job for my swap.
5.9 andy
PostPosted: Wed Jul 25, 2007 11:51 am    Post subject: Reply with quote
ok, i do feel verey comfortable doing this but my question now is what about my spedemoter and 4X4 indicator.
PostPosted: Wed Jul 25, 2007 7:51 pm    Post subject: Reply with quote
Speedo stuff should swap right over.. Indicator switch depends on what year t case you get.. If its a close year model it may work.. Otherwise it may not..
5.9 andy
PostPosted: Wed Jul 25, 2007 8:10 pm    Post subject: Reply with quote
its 5 years older than mine Confused
5.9 andy
PostPosted: Tue Aug 07, 2007 3:10 pm    Post subject: Reply with quote
ok guys, just droped ny crappy 249 today, got good news and bad news.
i will start with the bad,
(1) the yoke on my drive shaft wont fit on the tailshaft of my 231HD, the yoke has a larger diameter and just spins around the out put shaft,
(2) the plastic speedo sensor in the 231 case is a bit chewed up, i hope it is not a sign of terrily bad things in the case, but it turns smooth and shifts well, so i am opptimistic.
(3) it is verey dirty and greasy.
ok time for good news about the case.
...........um...um...um....um..um
(1) o yea, when i clean it up, it will be shiney Mr. Green
so as you can see, i am having more problems than blessings, but i kinda expected that.
