Gear lubricant and trac-Lok
fire_ant
PostPosted: Sat Aug 04, 2007 3:05 pm    Post subject: Gear lubricant and trac-Lok Reply with quote
Well, basically I want to change the front and rear axle fluid myself and I have a problem. My owner's manual says to use 75W-90 API-GL5 fluid, but it also says models equipped with trac-Lok require an additive. I don't know if I have trac Lok. I have a 1995 Jeep Grand Cherokee Limited 4x4 5.2L v8 with Quad Trac All-time 4 wheel drive. The Jeep has about 110,000 miles.
Mr. Green
5.9 andy
PostPosted: Sat Aug 04, 2007 3:27 pm    Post subject: Reply with quote
have you checked the FAQ?
that might help you out.
BTW.. track lock is a type of limited slip, so do u have a limied slip?
it may b a waste but, why dont you spend $5 and add it in there anyway
and if you dont have one mabe you will get lucky and a limited slip will magicly appear rofl rofl
PostPosted: Sun Aug 05, 2007 3:40 pm    Post subject: Reply with quote
you also have the option of just putting in synthetic lubricant , better for the gears and you don't have to worry about a limited slip additive .
5.9 andy
PostPosted: Mon Aug 06, 2007 4:29 pm    Post subject: Reply with quote
i did not know that!
what makes the synthetic not need the additive?
PostPosted: Mon Aug 06, 2007 4:57 pm    Post subject: Reply with quote
the 10$ you pay for a bottle compared to the 4$ Smile
that means im not sure . but you can just use synthetic , it even says on the bottle . i put synthetic in my limited slip with out a additive , and then i tested it by doing burn outs every were Smile
5.9 andy
PostPosted: Tue Aug 07, 2007 8:18 am    Post subject: Reply with quote
sweet!! fo shizzle
