BIG BRAKES!!!!!
5.9 andy
PostPosted: Fri Aug 03, 2007 7:39 pm    Post subject: BIG BRAKES!!!!! Reply with quote
Ok we all want big braks but we have wimpy single piston caliper brakes. we try with expensive rotors and high quality pads.
i cracked my fancy drilled rotors and decided to go ahead with my plans. i heard from some wierd guy in the junk yard that had a XJ had upgraded his front brakes by putting the front brakes of a WJ on it.
so i went for it and discovered some bumps, but all turned out AWSOME!!!
here is what you will need, its alot, and by doing this you will require additionl mods to ur jeep, but all are good. Very Happy
1. steering knuckels for a WJ
2. brake calipers and hangers for a WJ
3. front rotors for a 05 ford explorer
4. Axle shaft assembly off of a XJ (not shure what year, or if it matters)
5. 19/32 drill bit (to drill out the holes in the ford rotor so it fits over the lug studs
6. slightly extended brake lines, about 8in
7. new WJ brake pads. (make shure u get the right kind, there are 2)
8. a transfer case that has 2wd so u dont kill ur new U-jointed shafts
that should b it.
i have ran this setup on my dana 30 LP without dront DS because i am working on the axle and i am instaling a 30HP,
anyway, with this setup u cannot run ur ABS sensors (they ont fit in the WJ nuckle) but thats ok, i was able to lock up my front brakes of my zj doing at least 90 MPH, and i stoped fast.
i will be doing 100% final assembly of this in about 1 week and i will poast pics and i will make a write up for it.
if anyone has any questions, i will b more than happy 2 awnser them.
o yea, allmost 4 got, if u do this, u will have 11" rotors and duel piston caliper brakes, and you cannot run on a 15" rim if you have these brakes. un less they are steel and have 4" back spaceing , and even then it is not garonteeed.
**** just rembered another way to set up the breakes so that you dont need new shafts or new T-case.
you need a piece of steel pipe with an internal diameter of 1/2 inch. and a legth of .25 inches,
this spacer is 2 be inserted the brake havger and brake caliper, a slightly longer bolt will be required to securley hold the caliper.
quadna71
PostPosted: Sat Aug 04, 2007 3:15 am    Post subject: Re: BIG BRAKES!!!!! Reply with quote
5.9 andy wrote:
...i was able to lock up my front brakes of my zj doing at least 90 MPH, and i stoped fast...
isn't this a bad thing???
2003 TJ Sport
5.9 andy
PostPosted: Sat Aug 04, 2007 8:36 am    Post subject: Reply with quote
not realy.... unless you dont know how 2 control your self and ur vehicle in an emergency situation in which case you dont know what 2do u just mash the braks, yea its bad..
you just have to be able apply the the correct abount of brake pressure so you dont lock em up. its not that hard,
this brake upgrade has allready saved my life once.
PostPosted: Sat Aug 04, 2007 9:52 am    Post subject: Reply with quote
I was cetainly happy when I got rid of my ABS.. Anyone who knows anything about Chrysler ABS knows that if you happen to drive thru a puddle right before you mash your brakes they will go right to the floor and you will not stop.. Its a very bad feeling.. It happened to me several times before I ripped out all the ABS crap on mine.. I like being able to mash the pedal and have the brakes lock up.. If you do a rear disk conversion you will be able to stop very well and you will not have to lock up your front tires to stop..
Disk conversion on a grand is easy.. Just go to a bone yard and pull the disks off of a newer grand and put them on.. rofl Or if you have an 8.8 you can use brakes off of a police car or newer Exploder..
5.9 andy
PostPosted: Sat Aug 04, 2007 12:45 pm    Post subject: Reply with quote
i all ready got dick's in the rear,
and i dont try 2 lock up the fronts when i wana stop fast, it will actulay take you longer longer 2 stop if u lock em up as opposed to the point just before you lock em up.
quadna71
PostPosted: Sun Aug 05, 2007 4:39 pm    Post subject: Reply with quote
5.9 andy wrote:
not realy.... unless you dont know how 2 control your self and ur vehicle in an emergency situation in which case you dont know what 2do u just mash the braks, yea its bad...
i guess i'm confused. how exactly do you control your jeep once the tires have locked up when cruising at 90 mph?
5.9 andy wrote:
...i all ready got dick's in the rear...
and i think that this might possibly be the reason your mashing on the brakes in the first place!
chris (maybe the website needs an update on the porn/spam filter???)
2003 TJ Sport
PostPosted: Sun Aug 05, 2007 4:56 pm    Post subject: Reply with quote
rofl rofl rofl rofl
5.9 andy
PostPosted: Sun Aug 05, 2007 6:35 pm    Post subject: Reply with quote
well, you dont control it when its going 90 and you lock em up...i only did it for about 1/2 a second to see if they could do it, i immediatley let off.
BTW....that was a 100% typo, look at ur key board...the 'C' is verey close 2 the 'S'......so give me a little leeway.
5.9 andy
PostPosted: Tue Aug 07, 2007 8:27 am    Post subject: Reply with quote
i have a hard time believeing that no ZJ guys are intrested in making their brakes bigger.
PostPosted: Tue Aug 07, 2007 9:00 am    Post subject: Reply with quote
I have not had a problem with my ZJ brakes! All my other jeeps have rear drums, so front and rear disc is awesome. My fronts and rears have always worked flawlessly for me, even when wet or totally mudded up, hot or after breaking through ice puddles in the winter. If it ain't broke I won't fix it!!! Cool
Duncan
PostPosted: Tue Aug 07, 2007 10:36 am    Post subject: Reply with quote
My breaks are already all disk and have not given me any trouble.. Except when some crap got under the pads (I think... It occured right after I went though some mud) and then it ruined the rotors but they needed replacing anyway so it was no problem.
Also: Re: typo... Classic... I lol'd
joni0039
PostPosted: Fri Jun 26, 2009 6:22 pm    Post subject: Reply with quote
Can someone help me on this.
I've a AP racing caliper model CP5805 for stockcar.
Can I install the above caliper on my 2000 Jeep Grand Cherokee Limited?
Thanks.
