Identifying a melted fuse
NikkiS
PostPosted: Sat Aug 18, 2007 11:27 am    Post subject: Identifying a melted fuse Reply with quote
I started to replace the alternator on my 1994 cherokee limited today and whilst taking the battery out I noticed a black box screwed onto a chassis with a fuse inside. Where the fuse went into the box I noticed that the plastic had melted and dribbled slightly. I pulled the fuse out and half of the metal is gone.
I obviously stopped changing the alternator... now my question is... what is this fuse and what is the box?
Do I just need to replace the fuse or the whole box?
Thanks,
Nikki
NikkiS
PostPosted: Sat Aug 18, 2007 3:59 pm    Post subject: Hella fog lamps Reply with quote
OK it might not be too bad. Just checked out the fuse part number (003 510-36) and it appears that it's for the Hella fog lamps. These lamps have not worked since I got the jeep... I assume the busted fuse is the reason why.
PostPosted: Sun Aug 19, 2007 8:25 am    Post subject: Reply with quote
or what ever caused the fuse to blow
