AC settings 1,2&3 only work when driving
ak_bird_slayer
PostPosted: Wed Aug 29, 2007 8:49 pm    Post subject: AC settings 1,2&3 only work when driving Reply with quote
So I have a 99 jeep Cherokee sport with 110,000 miles on it. The car still runs great but in the last few weeks the climate control whether it is on AC or heat on setting 1,2&3 only work when the car is moving. But it works perfect on high (4). I thought maybe something was in the vents but I checked them all and they are fine. I don't know if just the switch is bad or the alternator isn't putting out enough power or what I have no clue. so any help would be greatly appreciated. Thanks a lot for you guys help.
PostPosted: Thu Aug 30, 2007 9:06 am    Post subject: Reply with quote
Is the blower fan turning on?
ak_bird_slayer
PostPosted: Thu Aug 30, 2007 2:27 pm    Post subject: Reply with quote
when you turn the switch you can her a small amount of air move for a second bu then it just stops until you start moving
dancerman
PostPosted: Fri Aug 31, 2007 2:56 am    Post subject: Reply with quote
I'd say if your dash voltmeter shows steady at 13 to 14 volts then the charging system is OK (assuming no other electrical systems are acting up). You can easily check the switch by pulling it out and testing it with an ohmmeter. I'd guess though that the blower motor is getting old and needs full voltage to spin it. It's curious that it only fails when not moving and low fan speed. Let us know what you do to fix it. Good luck.
PostPosted: Fri Aug 31, 2007 9:30 am    Post subject: Reply with quote
Yeah, it sounds like the volts are dropping down at idle. If the gauge is reading ok at idle then take a look at the plug for the blower. It's in the engine compartment. The blower on my 99 XJ was working on and off. The plug was loose, so I fixed it and the blower hasn't acted up since.
