Where did this come from? aluminum heat shield..
ecologito
PostPosted: Fri Oct 12, 2007 5:22 pm    Post subject: Where did this come from? aluminum heat shield.. Reply with quote
Today I was driving and I heard a weird noise, like something was dragging, I looked under the jeep xj 98 and I saw an aluminum plate, it looks like some sort if heat shield but couldn't figure out where it came from.
It has 4 or 6 holes I am not sure but I am guessing it is where it was bolted in to something.
Do you guys have any idea where it came from?
It was on the rear axle. I am not sure if this came loose from my jeep or picked it up on the road but I never really had a good look under my jeep and try to remember if it was there.
Any pictures of the stock jeep 98 would be great.
mj77724
PostPosted: Fri Oct 12, 2007 8:58 pm    Post subject: Reply with quote
i think what it is the heat sheid for the cat it bolts to the under side of the pan above the cat
marlen
DelmarvaXJ
PostPosted: Sat Oct 13, 2007 3:25 am    Post subject: Reply with quote
marlen
I agree, if it has a round shape, then it's most likely the heat shield off of your cat!
