Hard Starting, fuel pressure questions
davebl
PostPosted: Sun Sep 23, 2007 5:46 pm    Post subject: Hard Starting, fuel pressure questions Reply with quote
Not to sound like another hard start question.... but I just need some info about the fuel pump and fuel pressure.
My 98 ZJ, 5.2L with 127 has a difficult time starting, but once started, runs great. It basically just has to crank for about 5 - 6 seconds, then starts going.
I suspect fuel, so I got a pressure gauge, and first thing this morning put it on my fuel rail. 0 psi. So I turned my key to on, and again 0 psi. I cranked the car a few times, and now we had some pressure.... but it just starts going back down slowly. So I started it (now we had some fuel in the line), and of course it runs fine. The gauge is showing right at 70psi. I watched it for a few minutes running and it never moved from 70 psi.
So I suspect a fuel pressure regulator, which I believe is built into the fuel pump assembly. I'm thinking about just getting a whole new assembly, and then keeping the old one for a spare pump/parts/etc.
Any opinions of the Autozone vs. Napa vs. Dealer replacements?
Could there be something easier and cheaper to repair other than fuel pump related parts?
Thanks for your input guys.
Dave
__________________
PostPosted: Mon Oct 15, 2007 7:15 pm    Post subject: Reply with quote
Fuel pressure for a 98 ZJ should be between 44.2 and 54.2 psi.
RussellRowell
PostPosted: Mon Oct 15, 2007 8:43 pm    Post subject: Reply with quote
I'm not sure where the FPR is on a 98 but on a 94, it's attached to the fuel rail on the passenger side of engine.
If yours is like mine, I would first just change your FPR seals. There are 2 in mine and their 2 different sizes. I would also goto nappa. Better parts but thats my opinion. Dealership parts over priced. Good luck
1994 w327k
