need a computer
PostPosted: Wed Oct 17, 2007 4:53 pm    Post subject: need a computer Reply with quote
so my mechanic traced a number of problems to the ICM. So he disconnected and opened it up. first, the outer plastic casing is broken, and the heat-synch is corroded, and the inner resin that incases the board is cracked in multiple places. *the computer is not the original, it was replaced 2 years ago from a junkyard. we never really looked at it (our fault)
haven't had much luck in finding one in a salvage yard, rebuilt from dealership is $500 +/- ....
does anyone have a computer for a 1995 wrangler 2.5L I4 or know where to get one via reputable salvage yard or know a place that rebuilds them?
or if you have other suggestions...
no signal to relays when first started, takes 1 minute of cranking starter to attain fuel pressure, juice to relays etc.
lose of spark at various RPM's/speeds/gears (like a hiccup., not enough for tach. to show RPM loss but enough to feel, sometimes hard enough to feel 'clunk' in driveline
inconsistent idle speed - will have different idle speeds at different times, have not been able to distinguish a pattern
generally annoying.
also note: 140K miles, 2nd trans. most basic stuff checked rechecked replaced and rechecked...
help please....and thanks in advance
PostPosted: Thu Oct 18, 2007 6:04 pm    Post subject: Reply with quote
I have an ECM out of a 93 YJ 2.5/5spd....
98' TJ, 99' XJ
