Transfer Case
arxj
PostPosted: Sat Oct 20, 2007 3:23 pm    Post subject: Transfer Case Reply with quote
There is something fowled up with my transfer case i'm not sure what it is. Can I just take it off and still drive the jeep around? I intend to try to fix it and rebuild it if i have to. Can any one give me any pointers? I really don't want to have to buy a new one.
PostPosted: Sat Oct 20, 2007 3:41 pm    Post subject: Reply with quote
No, you can't drive without the t-case. rofl
If you post the problem or symptoms, someone may be able to help you.
arxj
PostPosted: Sat Oct 20, 2007 3:47 pm    Post subject: Reply with quote
well i was scared of that. It makes a bad grinding popping noise when it is in 4wd, but it is fine in 2wd.
PostPosted: Sat Oct 20, 2007 4:00 pm    Post subject: Reply with quote
The inside of the transfer case is a lot simpler than most people think. It's been awhile since I've taken one apart but there's a chain, a few gears, bearings, seals and shift forks. Even if you take it off the Jeep to rebuilt it, it will take less than a day.
lakeland713xj
PostPosted: Sat Oct 20, 2007 4:28 pm    Post subject: Reply with quote
does it stay in 4 wheel drive or pop in and out...the linkage might be lose or bad...
Jeep cherokee 98 4.0
6.5" rough county
33x12.50 toyo mts
arxj
PostPosted: Tue Oct 23, 2007 5:12 am    Post subject: Reply with quote
It will stay in 4wd just makes a really bad noise.
lakeland713xj
PostPosted: Tue Oct 23, 2007 9:28 am    Post subject: Reply with quote
oh hmm i unno...how come the noise is always if the T case is always spinning???
6.5" rough county
33x12.50 toyo mts
PostPosted: Tue Oct 23, 2007 9:56 am    Post subject: Reply with quote
Not all the gears spin in the tcase in 2wd. It's definitely something in the 4WD engagement system...a gear that is not engaging properly or a bad bearing...possibly even a loose chain. Does it do it in both 4hi and 4lo?
