obd11
tag
PostPosted: Sun Nov 18, 2007 2:46 pm    Post subject: obd11 Reply with quote
Just tried obd key trick on my 97 cherokee the display reads 1-9 then shows the milage , should it show the serial number? as the reference post states, or is it that there's no faults to display?........cheers
tag
PostPosted: Tue Nov 20, 2007 12:18 pm    Post subject: Reply with quote
Guess it must be ok then! serial number part must be a load of bollocks.............
PostPosted: Tue Nov 20, 2007 1:56 pm    Post subject: Reply with quote
The key trick doesn't work on all vehicles. As a matter of fact, the OBDII trick will not work on my 97 either....but the OBDI trick does. If the check engine light is on and the neither key trick is displaying codes, then you'll have to take it to someone that can pull the codes...or buy a reader.
