REAR END SWAP
rbjeepster
PostPosted: Thu Dec 13, 2007 3:46 pm    Post subject: REAR END SWAP Reply with quote
hey does anyone know if i can pull a dana 35 out a 1990 cherokee pioneer and put in a 93 chrysler 8.25 from a cherokee country.and does any one know the gearing on a cherkee country?
thanks
Billy's89XJ
PostPosted: Thu Dec 13, 2007 8:15 pm    Post subject: Re: REAR END SWAP Reply with quote
thanks
Why the 8.25??
There is a metal tag on the axle that will tell you the ratio.
Look under the Cherokee section sticky's and you should find your answers Wink
PostPosted: Thu Dec 13, 2007 8:27 pm    Post subject: Reply with quote
The 8.25 is stronger than the 35
I hope he wants to swap the 35 out for the 8.25
jppilot61
PostPosted: Fri Dec 14, 2007 3:38 am    Post subject: Reply with quote
A little bit better choice would be a newer 8.25 since it would have a wee bit larger axles (1.21" vs. 1.17") but I assume you have already have this one available to you?
Chrysler 8.25 - 27 spline, 1.17" diameter shafts, 8.25" ring gear, 3" axle tube - used 91-96
Chrysler 8.25 - 29 spline, 1.21" diameter shafts, 8.25" ring gear, 3" axle tube - used 97-01
Reference the Cherokee Spec's Sticky - a bunch of good info there!
1992 XJ Laredo
RE6130 4.5" XJ Super-Flex Kit
PostPosted: Fri Dec 14, 2007 10:51 am    Post subject: Reply with quote
Yes, that swap will work. The driveshaft may need to be shortened. Measure the length of your driveshaft, and the donor Jeeps shaft if possible. Otherwise you won't know till you have the new diff in place. Like Billy said, check the tags for axle ratios. Chance are they are both 3.55's.
rbjeepster
PostPosted: Fri Dec 14, 2007 11:28 am    Post subject: Reply with quote
alright thanks guys for all the feed back yeah i took my jeep to the rear end shop and the guy said it sounds like a carrier bearing is on its way out.so i knew i needed to do something i just wanna pull a 8.25 because i know its bigger and probably stronger off a cherokee in the wrecking yard with somewhat low miles. does anyone know where i can decode the axle tag?
c130herc
PostPosted: Fri Dec 14, 2007 12:38 pm    Post subject: Reply with quote
Look for a Dana 44 on an XJ first. Sometimes you get lucky and find them. I have found 2 in a yard.
PostPosted: Fri Dec 14, 2007 7:54 pm    Post subject: Reply with quote
It's the number circled in orange. Wink
rbjeepster
PostPosted: Sat Dec 15, 2007 1:30 am    Post subject: Reply with quote
alright thanks are the other numbers anything important?
Billy's89XJ
PostPosted: Sun Dec 16, 2007 10:17 am    Post subject: Reply with quote
I agree, if you have the money, if not the other will do fine Wink My local yard said he could order 6 of the Dana 44s from other yards Shocked BUT at 350 a pop Evil or Very Mad
PostPosted: Sun Dec 16, 2007 12:43 pm    Post subject: Reply with quote
If you do decide to go 8.25, go with one out of 97+. The 96 and prior 8.25's are not much stronger than a D35.
