I Have A 22Gal fuel cell set up.
HighRoller
PostPosted: Fri Dec 14, 2007 6:09 pm    Post subject: I Have A 22Gal fuel cell set up. Reply with quote
I obviously had to run this set up due to puncturing my OEM tank...
It's clean, I did it right. I don't smell gas but.....
Any Ideas on concealing it? I'd like to find a way to use some of the storage space around it & on top of it from time to time.....
headbang
Toliver09
PostPosted: Sun Dec 16, 2007 9:29 am    Post subject: Reply with quote
i'd consider making sort of a doghouse around it... then you can put things on either side of it, on top of it, even use it as a table Smile on the trail dining room
HighRoller
PostPosted: Sun Dec 16, 2007 10:54 am    Post subject: Reply with quote
I was thinking of something around those lines....But I'm not sure how im going to get around my fuel pump and lines beside the cell.....
Here look......See what I mean...?
headbang
Toliver09
PostPosted: Tue Dec 25, 2007 11:10 am    Post subject: Reply with quote
what you do with your fuel pump lines is a judgement call. building a box out of 1/2" or 3/4" plywood or something and then drilling out holes in the side so your lines can go through and then extend one side of the box out so your pump and lines are protected.
