poor acceleration
gibsonlane1
PostPosted: Sat Dec 15, 2007 2:13 am    Post subject: poor acceleration Reply with quote
Hi, firstly new member and would like to congratulate you all on a great and informative forum. My problem is as follows:- My Jeep 1998 2.5tdi sport has developed the following problem. Accelerates fine upto about 2000 rpm then tails off taking an age to build up to speed. Have changed fuel filter, turbo checks out fine. have tried locally to find someone who can run a diagnostic but to no avail. I live in March, cambridgeshire so any sugestions, pointer would be gratefully received.
Another problem which i have had since i brought the jeep is poor cabin heating. Have flushed the core both ways and is fine, changed thermostat and flushed system. Blower works fine, Heater control Knob opens and closes fine, the result is warm air at best! Engine running temp is under the 100 on temp gauge.
Many thanks in advance. Cheers
Toliver09
PostPosted: Sun Dec 16, 2007 9:24 am    Post subject: Reply with quote
could be the throttle positioning sensor, they tend to wear after a few years of driving
gibsonlane1
PostPosted: Mon Dec 17, 2007 2:19 am    Post subject: poor acceleration Reply with quote
many thanks for that, i'll get it checked out.
cheers.
gibsonlane1
PostPosted: Sun Dec 23, 2007 1:56 am    Post subject: Reply with quote
Accelerator cheked out ok. On the morning it was booked into a garage, it would only run for a few seconds the stop. Finally it would'nt fire at all with the guages all failing to register apart from handbrake and airbag warning lights. No engine check light came up! It's been towed into the garage and so far they have found the fuel pump is'nt putting out any pressure. I'll keep you posted!
2wd lame-o
PostPosted: Sun Dec 30, 2007 10:57 am    Post subject: cold out Reply with quote
maybe your fan clutch, some times they freeze up. whilst she is cold and not running try moving the fan blades. they should move freely.
gibsonlane1
PostPosted: Mon Dec 31, 2007 10:55 am    Post subject: Reply with quote
Many thanks, i'll check that out and keep you posted. Happy new year
