BLOWER MOTOR HELP!
meatheadz
PostPosted: Fri Dec 21, 2007 1:54 pm    Post subject: BLOWER MOTOR HELP! Reply with quote
Hello,
Ok My heater on my 95-YJ has been making crazy noises. I pulled the blower motor cover/vent cover off and I found a bic lighter in it. It has ripped all the blades off the blower fan and the motor shaft is all loose and out of whack. It makes horbile noises when spinning. Heres my problem: I cant figure out how to remove the old blower motor. As Im looking at it, it looks rivited in. Are their bolts somewhere, or do I have to cut off stock rivits? What am I missing here?
Thanks.
Ill post a pic, if I can ever figure this pic thing out.
PostPosted: Fri Dec 21, 2007 6:28 pm    Post subject: Reply with quote
Hey Meatheadz! Welcome!!
I don't own a YJ or I'd run out and take a look for you. My Haynes manual says there are screws.
meatheadz
PostPosted: Sat Dec 22, 2007 7:52 am    Post subject: wow that helps Reply with quote
hey man.
thanks so much for your help. That is much easier with a picture! Mr. Green
Troy
PostPosted: Sat Dec 22, 2007 9:34 am    Post subject: Reply with quote
Hope it helps! Cool
TheRo0sTer
PostPosted: Sun Dec 23, 2007 6:53 pm    Post subject: Reply with quote
Just unbolts! I had mine out in the 93 to try and lube it. Couldn't get the fan off the motor. Rolling Eyes Didn't want to break it and be stuck without it. Wink
