fuel pump delay
fishjrl
PostPosted: Fri Dec 28, 2007 12:33 pm    Post subject: fuel pump delay Reply with quote
alright, so here is my new problem
when i go to start my jeep (93 ZJ I6) i have to wait abou 15-30 seconds before the fuel pump will kick in. i turn the key to the on position and listen carefully until i hear a thump thump thump. after that my jeep starts fine. any ideas why this could be happening and how to fix it. i dont want to replace the pump if it doesnt need it. it still works fine but it just delays starting
thanks
PostPosted: Fri Dec 28, 2007 5:03 pm    Post subject: Reply with quote
try swapping the relay for the fuel pump with another relay or the same type (ac or something like that ) and see what happens . go giggle around the wires going to the tank . give it a kick .
that or check the ignition switch .
fuel filter never hurts . dont ask why , its just 10$ and doesn't hurt anything .
PostPosted: Fri Dec 28, 2007 6:53 pm    Post subject: Reply with quote
Run a wire to the fuel pump from the battery. See if the pump starts immediately or delayed with 12v directly to it.
PostPosted: Sat Dec 29, 2007 5:29 pm    Post subject: Reply with quote
Orange is correct.. This is the proper way to check the fuel pump..
You guys are good.. I dont even need to show up anymore.. rofl
fishjrl
PostPosted: Mon Dec 31, 2007 9:55 am    Post subject: Reply with quote
thanks guys
it makes total sense now
you guys are great
