Anyone have CAD data for D300 or SM420?
hansw3
PostPosted: Thu Dec 27, 2007 6:18 pm    Post subject: Anyone have CAD data for D300 or SM420? Reply with quote
I am mating D300 to SM420. CAD data on either would be useful! (2D or 3D)
hansw3
PostPosted: Sun Dec 30, 2007 9:17 am    Post subject: link to pics included Reply with quote
Here is couple images of what I'm working on:
http://picasaweb.google.com/hansw3/S...D300AdapterPic
It would be great to get actual CAD data. Some Jeep maniac out there must have at least the D300 data, if not the SM420 (older GM tranny). I modeled this stuff from measuring the parts with caliper, square and tape measure. In the image the SM420 case is only represented by the black flange portion of it that mates to the adapter. The adapter is 3/4" shorter than what Novak sells. I am putting this in cj5, so length is critical.
The SM420 has about 7.05:1 1st gear and the D300 has 2.62 low range. Compared to my stock T-150 and D20 I'll have a crawl ratio of 84 instead of 27.
PostPosted: Sun Dec 30, 2007 9:36 am    Post subject: Reply with quote
The link isn't working.
hansw3
PostPosted: Sun Dec 30, 2007 10:46 am    Post subject: 2nd link attempt Reply with quote
http://picasaweb.google.com/hansw3/SM420ToD300AdapterPic
If this doesn't work I'm not sure how to get a picture here. I tested the one I pasted into the last post and it worked on my computer.
hansw3
PostPosted: Sat Jan 26, 2008 11:21 pm    Post subject: Reply with quote
I am now looking to purchase the Novak kit.
After consulting some welding experts I have decided not to fabricate adapter. The modified input shaft would be the real issue. See below if you're interested.
there would be 50/50 chance that modifying my shaft would result in breakage for my abusive application (1400 ft-lbs at 400 rpm).
If modifying existing shaft:
* Anneal existing shaft and cut off end
* Weld on new female splined coupler
* Relieve weld stress
* Heat treat (through hardening would be more likely to break than induction hardening)
New shaft fabrication would cost about $450.
* Recommended material would be either 4140 or 4340 (recommended 4340 because of rotating shaft with high torque)
* Hardness would be determined by measuring existing shaft (rule of thumb- more torque requires higher hardness)
* Splines would be made by fitting up the mating parts I would supply to them until they fit.
