jeep caliper reinstall or alinement
knightnet
PostPosted: Tue Jan 01, 2008 4:31 pm    Post subject: jeep caliper reinstall or alinement Reply with quote
I have a 2000 jeep and trying to replace the front disk pads and all went well until i tried to reassemble the capiler. The bolts will not Aline up with the holes. Have tried just about everything and do not know what to do from here.
jppilot61
PostPosted: Tue Jan 01, 2008 5:30 pm    Post subject: Reply with quote
http://www.jeephorizons.com/tech/brake_front.html
Maybe this write-up will help?
Are you sure you put them back on the same way or did you inadertently rotate them 180 degrees?
Compress cylinder with Clamp if necessary?
Just suggestions . . .
Good Luck and let us know what you find!
1992 XJ Laredo
RE6130 4.5" XJ Super-Flex Kit
PostPosted: Tue Jan 01, 2008 6:54 pm    Post subject: Reply with quote
Sometimes I use a small srewdriver to get the holes aligned. Then the bolt will slide right in.
