Oil Pressure Drops to Zero while in Idle
hvrncruz
PostPosted: Sun Jan 06, 2008 11:26 am    Post subject: Oil Pressure Drops to Zero while in Idle Reply with quote
Recently, my 2001 Jeep Cherokee 4X4's enh oil pressure drops to zero while at a stop. Once the Jeep is up and running the pressure appears normal. Just changed the oil today and same issue.
Does anyone have any suggestions for me?
Thanks....
PostPosted: Sun Jan 06, 2008 3:26 pm    Post subject: Reply with quote
how many kms you got . did you change your filter .
i would put a master gage on the test port before i go believing everything the electronic gage on the dash board tells me .
how much steel was in your oil .
does it hot and cold ?
hvrncruz
PostPosted: Sun Jan 06, 2008 3:46 pm    Post subject: Reply with quote
88K and yes oil filter was changed.
I do not know how much steel was in the oil. Did not think to ask the mechs.
It usually starts up initially just fine. Everything works normally until about 10 to 15 minutes into the drive.
Will check with master gauge as soon as i can.
Thanks.....
Toliver09
PostPosted: Sun Jan 06, 2008 4:06 pm    Post subject: Reply with quote
sounds to me like a main bearing or seal. rebuild kits aren't much and include all of the main bearings and seals, head gasket, rings etc.
hvrncruz
PostPosted: Sun Jan 06, 2008 4:20 pm    Post subject: Reply with quote
Thanks for the input. I will talk to my mech tomorrow. Will let you all know if this fixes the problem.
Take care....
PostPosted: Sun Jan 06, 2008 9:10 pm    Post subject: Reply with quote
shouldn't of went through a bearing at 88 k . thats sad , for something like that you have to take it apart to see whats wrong .
drops right to 0? or just goes low .
hvrncruz
PostPosted: Mon Jan 07, 2008 8:53 am    Post subject: Reply with quote
drops straight to ZERO and the Check Gauge Light illuminates. I will have someone tear it apart and inspect.
Is it safe to drive in the meantime?
PostPosted: Mon Jan 07, 2008 7:07 pm    Post subject: Reply with quote
honestly put a master gage on the engine first , could just be a bad sending unit . if the gage reads 0 then you know you have problems . the master gage plums into a test port near your oil filter .
