cutting some fenders
lakeland713xj
PostPosted: Sun Jan 06, 2008 8:34 pm    Post subject: cutting some fenders Reply with quote
a local cherokee i saw today was on 5 inchs and 33's with no fenders and i loved the look...i was wondering how u do this...do you just take off the stock ones and cut or what..ive read oldforums about it but still couldnt figure it out..please explain
Jeep cherokee 98 4.0
6.5" rough county
33x12.50 toyo mts
PostPosted: Sun Jan 06, 2008 11:02 pm    Post subject: Reply with quote
no exterior fenders at all? you just open the hood and take the torx bolts out along the joint , two inside the door two at the bottom of the door a support brace on the inside and i think two 6 mm bolts on the front . might be 8mm .
you would definitely get a fine for no fenders at all .
to trim them well go on this website http://www.jeepsite.net/ and go to the fender trimming section on the left .
personally the guy on that site did it the slow way , but he might not have a very steady hand .
personally i would just get a pencil and put my thumb on the edge of the fender and drag the pencil around then go over it with marker , then chop it off with a sawzall or die grinder .
you could always use a protractor to draw the line and drill guide holes like did i suppose . or just watch what the hell your doing .
PostPosted: Mon Jan 07, 2008 11:32 am    Post subject: Reply with quote
I just cut mine until the tires quit rubbing, 33s on 4.5 inches of lift.
I could got a little higher on my particular fender style since there isn't anything behind there. I know on the newer XJs the washer fluid bottle is in the way
Me and berk9 sawed them, then used a 2x4 and a hammer to roll the sharp edge under so it wouldn't rub, for a 20 min job it came out damn good and clears the tires
PostPosted: Mon Jan 07, 2008 1:19 pm    Post subject: Reply with quote
Not in Florida! Mr. Green
lakeland713xj
PostPosted: Mon Jan 07, 2008 9:02 pm    Post subject: Reply with quote
i meant no fender flares like the stockers off just bear metal....sorry
6.5" rough county
33x12.50 toyo mts
PostPosted: Mon Jan 07, 2008 11:56 pm    Post subject: Reply with quote
the flares just unbolt from the inside . then you just have to deal with the holes
PostPosted: Tue Jan 08, 2008 3:38 am    Post subject: Reply with quote
On the '97 - '01 XJs, the wiper fluid reservoir is in a bad area, and can easily be nicked by a sawzall. I gotta replace mine since the liquid sealant is no longer holding mine together. If you don't go too far up you might be safe, but I went right to the seam of the top of the fender and encountered trouble.
