Will start or won"t start
drew42
PostPosted: Tue Dec 04, 2007 1:23 pm    Post subject: Will start or won"t start Reply with quote
How's it going guys ? Here we go again . Friday when I started to leave work , got in the truck and it would not start . Heard a clicking noise and thought it was the starter . Took that off and carried it to the auto parts store to have it tested . It tested good , and when I put it back it started , let it run for a while , turned it off and started it up again . So I turned it off to go inside . So when I came back to start it up again the same clicking noise again . Does anyone out there have an idea of whats going on ? Any help would be great . Thanks Crying or Very sad Bummin
Black on Black , V8 , Killer Chrome ,and Smokin' . And I have 5 dollars on a case of beer !
PostPosted: Tue Dec 04, 2007 5:13 pm    Post subject: Reply with quote
How's the battery? How's the volts when it doesn't start? How's the volts while it's running?
PostPosted: Tue Dec 04, 2007 7:43 pm    Post subject: Reply with quote
Could be a weak battery. The starter tested good, but what about the solenoid?
PostPosted: Tue Dec 04, 2007 11:52 pm    Post subject: Reply with quote
I had the same problem, the terminals on the battery were pretty dirty
drew42
PostPosted: Wed Dec 05, 2007 5:47 am    Post subject: Reply with quote
Thanks Guys , I checked the voltage only by gauge when I tried to re-start. It did look a little low . But also a co- worker told me that the same theig happened to them and it turned out to be the distribtor. Any insight on that ? Meanwhile I will try another battery to see if that is the culprit. Need to have my truck back , the little ladys mini-van is making me sad and also she wants it back Crying or Very sad
OnAll4s
PostPosted: Wed Dec 05, 2007 6:18 am    Post subject: Reply with quote
Yup, I'd bet it's the battery. The battery itself might actually be good, but perhaps your terminals need a good cleaning.
Gotta remember, it's winter time now... colder weather is going to affect the battery. A half-assed battery with half-assed terminals won't start the car as easily as they did 3 months ago in the warmer weather.
drew42
PostPosted: Wed Dec 05, 2007 6:51 am    Post subject: Reply with quote
Went and to check the battery and it tested good. My brother-in law told me that though the starter tested good it can have a bad (bendix) whatever that is . I mean I've heard that name before , but didn't do any homework on it . And also just on experience alone I did check the terminals , they are almost a little too clean .Please , I welcome any more suggestions to what the problem could be .
srinde
PostPosted: Wed Dec 05, 2007 9:28 am    Post subject: Reply with quote
neutral safety switch ?
OnAll4s
PostPosted: Thu Dec 06, 2007 7:07 am    Post subject: Reply with quote
drew42 wrote:
Went and to check the battery and it tested good. ...And also just on experience alone I did check the terminals , they are almost a little too clean .Please , I welcome any more suggestions to what the problem could be .
Did you actually clean the terminals? (i.e. scrape them inside and out with a wire brush) They may look clean from on top, but all it takes is a fine coat of corrosion between the terminal posts and the connectors to cause problems.
PostPosted: Thu Dec 06, 2007 6:37 pm    Post subject: Reply with quote
How's Black Beauty? Cool
drew42
PostPosted: Tue Dec 11, 2007 11:23 am    Post subject: Reply with quote
She is one evil bitch . After i made sure that the terminals on the battery were clean . Still didn't start . Left it alone unti'l it was time to leave work . And don't you know that she started right up. I was standing there looking like a big dummy . Happy that she started up but still don't know what would cause that to happen.
PostPosted: Tue Dec 11, 2007 6:35 pm    Post subject: Reply with quote
some people call the pinion on the starter that engages with the flywheel a bendix . he would be referring to the solenoid that puts it into mesh , with a low battery the connections can weld together on it and pretty much nuke it .
what i think , neutral start switch . wiggle around your shifter and see if it starts .
take your battery to get load tested at your parts store , should hold half the cold cranking amps for 15 seconds at 9.6 volts minimum if i remember right .
at the same time i would replace the positive wire going to the starter and check the ground .
or just go buy a new battery or get a battery blanket , at 0C your battery's effectivness is down to 68% and 30% at -20 .
battery blankets cost nothing to run . what was the voltage on your battery not running ? 12.6? wouldn't want it any lower then that .
FARMER
PostPosted: Fri Dec 14, 2007 5:00 pm    Post subject: Reply with quote
Years ago I had a Ford Ranger that would not start occasionally, I did all the tests that were described above to no avail, it ended up being a burnt plate in the starter motor, every time the starter stopped on that plate it would only click.
PostPosted: Wed Jan 16, 2008 9:12 pm    Post subject: Reply with quote
What's up buddy? Did you get it going or what? Sad
terryh80
PostPosted: Thu Jan 17, 2008 9:10 am    Post subject: Battery Cables Reply with quote
I had a vehicle that would do that off and on. About drove me crazy. Finally found that the cables were corroded inside the cable clamps. You couldn't really see it but if you wiggled the cable right at the clamp it would start. New cables, no problem.
