BFG MT Tire Pressure
hustler
PostPosted: Thu Jan 17, 2008 4:16 pm    Post subject: BFG MT Tire Pressure Reply with quote
Hey guys,
I have some 32x11.5" BFG MT tires on my TJ. If anyone is running the same tire/size what are you running for air pressure? I have about 28 in there for the road ... I think I'm in the ballpark.
Brett
P.s. I didnt end up getting them siped for winter traction, they're actually much better than I was expecting as they came from the factory!
PostPosted: Mon Jan 21, 2008 8:17 pm    Post subject: Reply with quote
You need to figure out your proper pressure. You want even contact across the contact patch of the tire tread. Try googling for a writeup on the chalk test.
PostPosted: Mon Jan 21, 2008 8:59 pm    Post subject: Reply with quote
http://www.jeephorizons.com/phpbb/viewtopic.php?t=1215&highlight=credit+card
Also, try Chuck's credit card trick.
hustler
PostPosted: Tue Jan 22, 2008 8:22 pm    Post subject: Reply with quote
Thanks for the link, I tried the chalk routine, but it's fairly wet and winterey here right now so the accuracy was a little suspect. The credit card should work well in the garage, I never even thought of that.
