wheels
hammerhead
PostPosted: Wed Jan 30, 2008 2:57 pm    Post subject: wheels Reply with quote
Does any one know if the 2007 jeep has the same wheel bolt pattern as the 97-06 tj
PostPosted: Wed Jan 30, 2008 3:26 pm    Post subject: Reply with quote
I'll assume your referring to a JK?
The JK has 5 on 5".
The TJ has 5 on 4.5".
hammerhead
PostPosted: Wed Jan 30, 2008 3:39 pm    Post subject: wheels Reply with quote
Thanks for the info.I just wanted to see if I could use the wheels off an 07 wrangler!but I see I can't
TJRobbie00
PostPosted: Sat Feb 02, 2008 7:45 pm    Post subject: Reply with quote
actually you can use JK whhels on a TJ! or any other jeep with a 4.5 bolt pattern as long as you get these
http://www.4wd.com/productdetails.aspx?jeep-sid=0&plID=480&partID=15868
