*SERVICE 4WD SWITCH*
quietstorm
PostPosted: Thu Feb 07, 2008 5:30 pm    Post subject: *SERVICE 4WD SWITCH* Reply with quote
I haven't been able to pick up a manual in the 2 weeks I've owned this ZJ, but the screen keeps popping up with a message saying; *SERVICE 4WD SWITCH*
Anyone have any ideas on what it is or how to shut up the F'ing computer? Very Happy
BTW it's a 95 5.2 RH46, with stock TC.
Thanks,
Jason
PostPosted: Thu Feb 07, 2008 6:18 pm    Post subject: Reply with quote
I would look at the sensor on the t-case. There are two, the one at the rear on the tailshaft housing is for the speedo, don't worry about that one. The other sensor with wires going to it is the one for the 4WD. The plug may be loose or corroded. If not it may need to be replaced. I have mine unplugged because I swapped in a 231 and the 249 sensor wouldn't work. I don't receive any messages.
quietstorm
PostPosted: Thu Feb 07, 2008 8:57 pm    Post subject: Reply with quote
I'll do that first thing in the morning!
Thanks for your help!
quietstorm
PostPosted: Sat Feb 09, 2008 11:48 am    Post subject: Reply with quote
So, got under there, cleaned out all the connections really well, and no luck.
Man that computer is annoying!!!
Any other ideas?
I need a manual.
PostPosted: Sat Feb 09, 2008 12:27 pm    Post subject: Reply with quote
If you leave the sensor unplugged, does it still display the message? You'll have to unplug it while the Jeep is off, then turn the key forward. If you get the message while it's unplugged you can eliminate the sensor as the problem. If you don't get the message while it's unplugged then the sensor is bad.
