Anyone heard of a Stealth?
fb902350
PostPosted: Mon Feb 25, 2008 4:50 am    Post subject: Anyone heard of a Stealth? Reply with quote
Hi All,
First off, I'm from the other side of the pond (England) so apologies if i'm a little confusing Very Happy
I'm looking into buying a Jeep Cherokee 4.0 Stealth (1994)
now having a search through these forums, i can't see any reference to one on here at all.
Does any one know of this model? is it called something different in the US?
thanks, fb...
djgrayxj
PostPosted: Mon Feb 25, 2008 6:21 am    Post subject: Reply with quote
From Google search
Hope this helps
http://www.wjjeeps.com/custom/stealth.htm
djgrayxj
PostPosted: Mon Feb 25, 2008 6:43 am    Post subject: Reply with quote
Further Google search
Nice looking XJ
http://www.high-lo.com/Jeep/default.html
fb902350
PostPosted: Mon Feb 25, 2008 7:07 am    Post subject: Reply with quote
Nice looking XJ
Yeah thats the one. the XJ
do you have an equivalent over in the US?
I've had a look at it once so far, and will go back to have a second look on wednesday. all being good i'll buy Very Happy
Tim Hallam
PostPosted: Mon Feb 25, 2008 2:35 pm    Post subject: Reply with quote
It must be a Euro exclussive...
Probably just the trim level.
If the price is right, I'd buy it.
Tim
P.S. I'm no expert though.
PostPosted: Mon Feb 25, 2008 7:03 pm    Post subject: Reply with quote
i have the same seats out of a limited .
fb902350
PostPosted: Tue Feb 26, 2008 3:26 am    Post subject: Reply with quote
well its lowered and i think a few other changes. and for the UK prob a good price. £2000 ($4000) which is dirt cheap over here!!!
if all goes well, going over tomorrow to trade my BMW 318i in for it Very Happy fun stuff!
anyone got anything I should especially look out for on them, I've heard to check for rust under the passenger's side, and no clunking from the 4WD.
anything else you guys can think of often goes wrong with the XJ??
djgrayxj
PostPosted: Tue Feb 26, 2008 5:21 pm    Post subject: Reply with quote
Los Angeles XJ for Sale No Stealth’s
94 Cherokee Trim Levels were SE, Sport & Country no Stealth
http://consumerguide.cars.com/go/search/search_results.jsp?ct=38&tracktype=usedcc&searchType=22&cid=&dlid=&dgid=&amid=&cname=&rd=&ddrd=30&zc=91790&makeid=23&modelid=244&pageNumber=&numResultsPerPage=50&largeNumResultsPerPage=0&sortorder=descending&sortfield=PRICE%20descending&certifiedOnly=false&criteria=K-|E-|M-_23_|H-|D-_244_|N-N|R-50|I-1|P-PRICE%20descending|Q-descending|X-popular|Z-91790&aff=cg
djgrayxj
PostPosted: Tue Feb 26, 2008 5:35 pm    Post subject: Reply with quote
My Zip 91790
djgrayxj
PostPosted: Wed Feb 27, 2008 1:57 am    Post subject: Reply with quote
Low gas mileage & low top speed plus prone to rear main leak & sagging rear springs.
Note Height you indicated lowered was it done in a professional manner?
Happy shopping.
Dimensions
(There may be small differences, dependent upon trim level and/or optional equipment)
Wheelbase = 101.4"
Overall length = 165.3" - 168.8"
Overall width = 67.9" - 70.5"
Track = 58"
Height = 64" (with roof rack 66.8")
Ground clearance from differentials = 7.3" (Upcountry = 8.3")
Approach angle = 37.6* - 38*
Departure angle = 31* - 32.1*
Breakover angle = 21* - 21.9*
Curb weight 2wd = 2,891 lbs - 2,993 lbs
Curb weight 4wd = 3,057 lbs - 3,386 lbs
Cargo capacity = 71.0 cu ft.
fb902350
PostPosted: Wed Feb 27, 2008 3:12 am    Post subject: Reply with quote
Yeah, the stealth was actually a trim offered in thr UK by jeep it turns out. so all legit.
I did notice the door hinges on the drivers door didn't seem to sturdy, is this common?
cheers folks
kaos
PostPosted: Wed Feb 27, 2008 3:26 pm    Post subject: Reply with quote
There have been some problems with the hinges, yes. See http://www.lunghd.com/Tech_Articles/Body/Hinges.htm.
Regards,
Kári
djgrayxj
PostPosted: Thu Feb 28, 2008 3:17 am    Post subject: Reply with quote
Did you by the XJ
djgrayxj
Did you by the XJ
fb902350
PostPosted: Thu Feb 28, 2008 7:12 am    Post subject: Reply with quote
Haha, nope. Turned out to be a bit of a wreck.
>wouldn't shift from 2wd to 4wd,
>radiator fluid was just brown metallic water
>major rust under the front footwells
>exhaust blowing about half way along
>belts whinning
>very jerky in reverse
>none of the lighting or alarm working
>seats almost worn through
>documentation not matching up with an online check
not a chance, however have seen anothe rcherokee, though not stealth today, and think i'm going with that instead. this one checks out!
