Grinding noise coming from right front wheel
mikebitton
PostPosted: Sun Feb 24, 2008 12:16 pm    Post subject: Grinding noise coming from right front wheel Reply with quote
This noise only happens after I've driven a mile or two, and I only hear it at speeds slower than 40 miles per hour. It's kinda like "ga-RUNK, ga-RUNK, ga-RUNK." The sound is most noticeable at speeds under 15 miles per hour, and it's really, really annoying.
I think it's got something to do with the brakes, because when I push on the brakes, even just a little bit, the noise stops. As soon as I let off the brakes, though, the noise kicks in again.
I replaced my front brake pads about a year ago. I had some trouble getting the calipers to cooperate. The noise is new, though. Maybe I fouled up the right front caliper? If so, what do you suggest I do next?
I'm committed to doing as much work as I can on the Jeep by myself. Handing over cash to mechanics is not my idea of fun as a Jeep owner! I wanna learn how to wrench on this thing!
PostPosted: Sun Feb 24, 2008 4:47 pm    Post subject: Reply with quote
might be a wheel bearing . drive it around and see how hot it gets .
or the caliper is seized , do you feel a pulsation in your pedal when you press on the breaks , if so the rotor is warped .
PostPosted: Sun Feb 24, 2008 9:49 pm    Post subject: Reply with quote
Jack it up til that tire is off the ground and grab it at 9and 3 and wiggle.. If it wiggles .. Check your balljoints.. If not. Grab it at 12 and 6 and wiggle.. If that has some wiggle.. You need to replace your unit bearing...
the hub should feel hot as Brad said after a drive.. If its bad....
PostPosted: Sun Feb 24, 2008 9:57 pm    Post subject: Reply with quote
i should add in don't stick your tung on the bearing , in fact use some one you don't like . seriously they can get glowing , use the back of your hand to feel for heat or spray some water on it .
wiggling the tire like swampy said works well and you don't have to waste gas . Smile especially with that dahm new carbon tax coming out pissed dahm you liberals .
you could also try greasing everything under your front end , i have had a lot of annoying noises go away and even thunks just by greasing everything .
PostPosted: Mon Feb 25, 2008 8:49 am    Post subject: Reply with quote
I would take a look at the axle u-joints.
Brad S
PostPosted: Wed Feb 27, 2008 5:35 pm    Post subject: Reply with quote
I did this test on my own zj and it appears to have some wiggle in the 9 and 3 position. The 12 and 6 has none whatsoever, so I am guessing that the 3 and 9's small play is bad, is that correct?
I've also notice that the jeep seems to 'wander' on the road - could my ball joints need replaced?
ken692
PostPosted: Thu Feb 28, 2008 3:24 pm    Post subject: Reply with quote
sounds like one of the brake pads has come loose
pop that wheel off and see, before you need a $100 rotor
hope this helps
K-
PostPosted: Thu Feb 28, 2008 6:27 pm    Post subject: Reply with quote
You should have someone wiggle the tire while you look from behind. If there is no movement at the ball joints, you have bad bearings.
kaos
PostPosted: Fri Feb 29, 2008 2:08 am    Post subject: Reply with quote
Isn't a wiggle at 3 and 9 o'clock, but none at 6 and 12, an indication of bad tie rod joint's, rather than ball-joints or bearings? I mean, a bad bearing should cause a wiggle in any position, and the ball joints, being located at 12 and 6 o'clock positions (approximately) should cause a wiggle in that position, unless I'm misunderstanding something?
Regards,
Kári
PostPosted: Fri Feb 29, 2008 8:19 am    Post subject: Reply with quote
Regards,
Kári
Pretty much, that's why I suggested just looking to see what's moving.
12 and 6 is a ball joint check not 3 and 9.
erizzo1234
PostPosted: Fri Feb 29, 2008 10:41 am    Post subject: Reply with quote
yeah twelve and six. tool
Brad S
PostPosted: Fri Feb 29, 2008 2:06 pm    Post subject: Reply with quote
Well I will be inspecting my tie rod joints tomorrow then. Kinda sucks that they wheel end joint isn't changable - that you have to replace the whole thing if it is bad... anyone done a work-around for this?
