Help with bolt sizes
94greenmachine
PostPosted: Mon Mar 03, 2008 9:01 am    Post subject: Help with bolt sizes Reply with quote
I have a 1994 grand cherokee limited that we are trying to put the tranny back in. Problem is that some key bolts are missing. The dealer was a jerk and first ordered wrong size and then would not give out size info so I could get them cheaper elsewhere. Also would not refund money. I need bellhousing bolts, front driveshaft bolts and crossmember bolts. Any info will help. I have a place that stocks alot of different sized bolts but need the size to get. Or anywhere that I can research will help too. Thanks for any info. Time is of the essence.
PostPosted: Mon Mar 03, 2008 7:08 pm    Post subject: Reply with quote
I wish I could help.. but all my bolts are back in the bellhousing...
You are missing all of your bolts???
PostPosted: Mon Mar 03, 2008 7:11 pm    Post subject: Reply with quote
they are all metric , best bet is to buy a m6 m8 m10 m12 m14 bolt and try them all out , measure how deep the holes are with a vernier caliper . and go buy it all .
or go to a bone yard and see if you can pull out all those bolts .
94greenmachine
PostPosted: Tue Mar 04, 2008 2:13 am    Post subject: Reply with quote
Ended up getting them at stealership. $15.00 for 5 bolts - what a rip off. Thanks for the replies though.
