700R4 Swap... Computer Code Issue
DavidXJ
PostPosted: Mon Apr 28, 2008 3:21 pm    Post subject: 700R4 Swap... Computer Code Issue Reply with quote
I would love to put a 700R4 4-speed Automatic to replace my AW4 in my 1998 Cherokee classic, mainly for shifting reasons. I can get an engine/tranmission/transfer case for $150 from a guy who's moving. But...
Having a "Check Engine" code makes you not pass smog, and if I unplug my AW4 from the computer, it will forever produce an error code and illuminate the "Check Engine" light. Does anyone know if there is anything I can do about this, such as replace the computer with one from a 1998 with a manual tranmission? If a manual transmission computer would take care of the error code problem, would it cause any other problems?
02tj
PostPosted: Wed Apr 30, 2008 11:27 am    Post subject: Reply with quote
I saw a swap in JP mag but think it was in a TJ, They ended up swaping in a manual computer from a 5spd tj. should work in a xj if you get the computer out of a 5spd xj. that way you get rid of the computer serching for gear selection and lock-out.
DavidXJ
PostPosted: Wed Apr 30, 2008 11:33 am    Post subject: Reply with quote
Awesome. Thanks for the info. That seems to confirm my theory about a manual transmission computer.
02tj
PostPosted: Wed Apr 30, 2008 12:13 pm    Post subject: Reply with quote
Awesome! good luck.
