4wd low indicator lamp not illuminating
bironfish
PostPosted: Mon May 19, 2008 8:42 pm    Post subject: 4wd low indicator lamp not illuminating Reply with quote
hi again,
when i bought the 96 cherokee the 4wd low indicator lamp didnt illuminate although it was in low range.. i went to dealer and a mechanic slid under the vehicle and rectified the prob in 30sec!!
It has occurred again...it goes into low range as i can tell by the gearing but the indicator lamp wont come on (4wd low)...the part time indicator is on in the low position..i have checked the shift rod connector and it is tight ..what did the mechanic do to rectify this problem so quickly...it cant be much!! please enlighten me... Embarassed
kaos
PostPosted: Tue May 20, 2008 1:16 am    Post subject: Reply with quote
He probably just unplugged and replugged the connector on the T-case mode switch, possibly squirting some contact cleaner in it.
Other possibilities:
-Burnt out bulb in the indicator.
-Misadjustment or wear in the shift linkage, so that while the T-case does go into low range, it doesnt' quite reach far enough to activate the switch. (Not actually sure whether this is possible, but might be worth checking.)
-Bad connection somewhere in the circuit.
Best regards,
Kári
bironfish
PostPosted: Tue May 20, 2008 1:57 am    Post subject: Reply with quote
thankyou,,,
as i have stated i thought it just wasnt going in far enough for the light to illuminate so i tried the adjustment but no good... i think i may try to unplug and lubricate the plug thank you sir..as far as the globe goes ..if i had no indicator at all i would agree ,,but the part time is on so i will try what you sudggested ...thanks again
kaos
PostPosted: Wed May 21, 2008 1:27 am    Post subject: Reply with quote
The 4wd low indicator has it's own seperate bulb, so this is still a possibility.
Best regards,
Kári
