Fuel filter???
440_Magnum
PostPosted: Fri May 30, 2008 5:52 pm    Post subject: Fuel filter??? Reply with quote
Hey gang. I 've been going through my "new to me" 99 XJ changing fluids, filters, and all the other stuff that's probably been neglected. I also got a factory service manual, and if I read it right the ONLY fuel filter is a combined filter/pressure regulator that mounts on the fuel pump module and requires you to drop the gas tank.
My first reaction is "you gotta be kidding." Is that really the only fuel filter? Is it just a strainer, or is it a paper filter? I assume that I should replace it after 120,000 miles, but if its just a screen maybe not.
kaos
PostPosted: Sat May 31, 2008 2:22 am    Post subject: Reply with quote
On my '93 XJ there was a fuel filter bolted to the inside of the driver's side "frame" rail, close to the fuel tank. The filter in the tank was indeed just a strainer.
Regards
Kári
440_Magnum
PostPosted: Sat May 31, 2008 1:14 pm    Post subject: Reply with quote
Regards
Kári
That's exactly how my wife's 93 Eagle Vision is. But this 99XJ is decidedly different. I'm a little annoyed that Chrysler combined something disposable like a fuel filter with something expensive like the fuel pressure regulator. That's the kind of bullsh*t engineering I expect from Honda or Toyota pissed But so far that's the only disappointment I've had with the truck, so I'll live with it.
Franko
PostPosted: Wed Jul 09, 2008 1:54 pm    Post subject: Reply with quote
440_Magnum wrote:
Regards
Kári
In all my days of building imports and domestics its the domestics that are always engineered to require service and high parts prices. I have dealt extensively with Honda's in the past and most jobs can be performed in under half the time, spending under half the money as would be on my domestics. Granted my Jeep is a lot better than my Ford in this aspect but still faaaaaaaaaar worse than any of my Honda's. But yes that is BS engineering.
PostPosted: Sat Jul 19, 2008 2:58 am    Post subject: Reply with quote
its a Chrysler thing they did it for a few years on a lot of there vehicles .
its ok the filter for my diesel jetta is 120$
