Need help! 242 J drivechain replacement
white00gcl
PostPosted: Sat May 31, 2008 12:35 pm    Post subject: Need help! 242 J drivechain replacement Reply with quote
I have been told I could replace the drivechain in my wife's 2000 Grand Cherokee with a NP 242 J transfer case. I started it today, but couldn't get the read driveshaft loose from the transfer case. It has the boot at the front and the plate mounted to the case. I have read all the forums I colud on doing this, but cannot find anything that explains how to get this driveshaft off. Can someone please help? Confused
WHEN THE RICH WAGE WAR IT'S THE POOR THAT DIE!!!
PostPosted: Sun Jun 08, 2008 11:36 pm    Post subject: Reply with quote
the rear drive shaft or front ?
for the rear undo the 4 small bolts on the rear drive shaft u-joint then push forward on the shaft so it slips in the transfer case then lower it and pull it out .
a small amount of oil will come out (ATF)
for the front just undo the 4 bolts holding the u-joint on the front axle then the 4 bolts holding the u-joint on the front of the transfer case .
have you ever done something like this before , a t-case is a complex little box .
if that doesn't work then you have something i have never seen on a 242 before in that case take a picture and post it . im guessing it isn't lifted and doesn't have a slip yoke eliminator if it did it would be just like removing the front shaft .
white00gcl
PostPosted: Mon Jun 09, 2008 5:19 am    Post subject: Reply with quote
thanks for response. we finished project already.
