Stalling only in reverse???
Gearhead41987
PostPosted: Tue Jun 10, 2008 10:26 am    Post subject: Stalling only in reverse??? Reply with quote
Hi All,
I'm a pretty good mechanic, but I'm new to Jeeps and the quirks that they have...
I have a '96 Cherokee sport, 3" lift and 31-10.50 tires. My motor blew up right after I bought it, so I had it replaced with the motor from a 97 Wrangler. It has been running GREAT. No smoke, blowby, noises, or oil burn.
However, I decided to run some fuel system treatment through it. I put it in a full tank, and last night (by then I was on 1\4 tank) When I was driving on the interstate (about 70mph) It would buck like the motor died, then came back and ran fine... It did this a few times randomly, so I slowed down a little, but it still did it randomly. I went to the pub, had a pint, and then went back to my jeep and when I cranked it up, it died within three seconds, cranked right back up then did the same thing again. The third time it stayed running fine. But when I put it in reverse It dies instantly. Like I turned the ignition switch off. Cranks right back up. If I put it in drive it runs fine. But thus far I have yet to get it to stay running in reverse. even if I let it roll backwards on a hill then put it in reverse so the motor doesn't have to slow down. If I feather the throttle, I can make it keep running, but it bucks and you can't get anywhere. It seriously feels just like It would if I were to turn the switch on and off. I'm going to replace the fuel filter today, and I'll clean the IAC valve tonight, but I'm almost thinking electrical.... But everything still works with the ignition still on and the gear selector in reverse. So I don't really know... Any suggestions? Cause I can't come up with a good reason for it to start this all of a sudden...
2bucks
PostPosted: Wed Jun 11, 2008 3:42 am    Post subject: Reply with quote
Check for frayed wire(s) on crank shaft position sensor.
Gearhead41987
PostPosted: Wed Jun 11, 2008 10:28 am    Post subject: Reply with quote
It was a binding torque converter.
I have had to follow up behind the morons that put my engine in.
Again.
They didn't tighten the transmission bolts down, and aparently they had worked themselves about 2 turns out. Enough to give me about a 1/4 inch gap between the bell housing and the engine block. Letting the engine shift slightly when it was put in reverse and binding the converter.
I just happened to notice when I had the hood open and blipped the throttle after I cleaned the intake. I saw the motor move and the transmission stay still. Scary huh?
PostPosted: Wed Jun 11, 2008 7:08 pm    Post subject: Reply with quote
seen that before in a Cherokee actually . never touched from factory , it just worked loose . made a really bad noise when you hit a speed bump .
Gearhead41987
PostPosted: Thu Jun 12, 2008 4:01 am    Post subject: Reply with quote
Mine would make a noise if you accelerated and it shifted from 4th to 3rd.
I think the flywheel teeth were barely scrubbing the bellhousing....
