manual transmission hard shift!
masterblaster
PostPosted: Fri Jul 11, 2008 6:55 am    Post subject: manual transmission hard shift! Reply with quote
I got a 1993 4.0 cherokee 5-speed, sometimes it's hard to shift gears ! 1st to 2nd and so on while driving , And when your stoped hard to go in 1st gear . The jeep has 190 thousand miles, Is it time to rebiuld tranny?thank's for help
PostPosted: Fri Jul 11, 2008 7:16 am    Post subject: Reply with quote
Take a look at the clutch master cylinder to see if the fluid is up to level. Are you having a hard time getting it to shift into first or are you saying once in first the Jeep has a hard time moving?
I would change the oil in the tranny if you haven't already. It may not help your problem, but it'll prolong the life of your transmission.
masterblaster
PostPosted: Fri Jul 11, 2008 7:47 am    Post subject: tranny shift Reply with quote
The fluid is good in master cylynder also had trannyfliud replaced. The jeep goes fine once in gear , it;s just changing gears from one to the other (actualy going in gear is hard you some times have to force).Then some times falls right in.thank's for the reply.
PostPosted: Fri Jul 11, 2008 10:18 am    Post subject: Reply with quote
Have you bled the clutch?
masterblaster
PostPosted: Fri Jul 11, 2008 11:27 am    Post subject: trainny shifting Reply with quote
Thats the next thing i was going to try! But if that does not work is it possible the syncroniser are going bad?
PostPosted: Sat Jul 19, 2008 3:07 am    Post subject: Reply with quote
try thinner oil in the transmission .
whats the clutch like for wear ?i would replace it before tranny , and buy a tranny a wrecker before i had that one rebuilt unless your going to do it .
know how to power shift ? i would try that and see if it changes or double clutch , and see what happens .
