85 cherokee lighting problems!!!!!!!!
jeepcherokee85
PostPosted: Sun Jul 27, 2008 6:25 pm    Post subject: 85 cherokee lighting problems!!!!!!!! Reply with quote
i have a 1985 jeep cherokee and when its is running and the head lights are on i have like no volts and when i turn on the turn signals the lights dimm with the turn signals! and when i hit the brakes its the same thing!! and after i have been driving for a while and i shut it off and go to start it a couple mins after and it doesnt wanna start like the battery is low!! if anyone has advice for my problems it would help me alot!!
unforgiven
PostPosted: Sun Jul 27, 2008 6:41 pm    Post subject: Reply with quote
Sounds like either your alternator or connections are crapping out.
Take the alternator to get tested if you can't find any bad connections.
I have had that happen before on one vehicle, where it turned out to be the starter that was bad, and not the alt.
1 sticker !!! lol
jeepcherokee85
PostPosted: Sun Jul 27, 2008 7:06 pm    Post subject: Reply with quote
i think my starter is starting to go out!!
it squals sometimes when i go to start it
PostPosted: Sun Jul 27, 2008 9:21 pm    Post subject: Reply with quote
prolly , replace your grounds from battery to engine and check ground strap from head to firewall.
jeepcherokee85
PostPosted: Sun Aug 03, 2008 10:41 am    Post subject: Reply with quote
ya i just figured it out it was the ground sprap from the firewall to the back on the block, its wasnt hooked up at all i got a new ground strap and everything works just fine thanks for all you help!!
