abs light and noise from bellhousing
Mcgorty
PostPosted: Sat Nov 25, 2006 5:17 pm    Post subject: abs light and noise from bellhousing Reply with quote
I have a stock 99 Wrangler sahara Recently the carrier bearing seized and took the carrier with it. I replaced the carrier and ring and pinion. What a job that is, 8 hours of shimming and getting that perfect gear mesh. Anyway.... it's back together and I now have my abs light on. I plugged the 2 connections in when I installed the rearend back in the jeep. Any troubleshooting idea's.
2nd thing. I have a noise coming from the bellhousing transmission area...... not sure if it's a clink/clank/rattle or what the proper term is. It shows it's face during shifts when the clutch is pushed in. Also hear it when letting off the gas and getting back on it sometimes. Clutch feels o.k. but sometimes I get a little grind going into 2nd.
Thanks
John
